Hello Forum,
I am using Nexcloud 13.1-RELEASE-p9 installed as a plugin inside of TrueNAS Core 13.0-U6.4. I tried updating via the web-UI. (I now know that was a bad idea…)
First it Failed at the Backup Step. Than I restartet the server and tried it again.
I get the error: “pkg error: py39-fail2ban :,py39-certbot : Refusing to fetch artifact and run post_install.sh”
And now I’m stuck at maintenance mode.
I cannot ssh into it, so I use the TrueNAS shell of the jail.
I tried modifying the config.php and change the maintenance-mode value to false but that didn’t work.
I tried commands from different forums like
“sudo -u www-data php occ maintenance:mode --off”
But these didn’t work either.
It doesn’t even know sudo. I can change to root via su but even then it cannot “open the input file”
Can someone please explain to me what is wrong here and how I can turn of maintenance mode?
Thanks
