Hi everyone,
I’m having trouble setting up my Nest cam to record, specifically having an issue with “no access to path” error.
Here’s my setup:
OS: Truenas Scale ElectricEel-24.10.1
App version: Core 2025.2.4
Storage settings:
Configuration.yaml:
default_config:
tts:
- platform: google_translate
automation: !include automations.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
recorder:
purge_keep_days: 6
commit_interval: 3
db_url: postgresql://home-assistant:SVk%2A%26%5E2o334JHSs@postgres:5432/home-assistant?sslmode=disable
Action yaml:
action: camera.record
metadata: {}
data:
duration: 30
lookback: 0
filename: >-
filename: /mnt3. /NAS 16TB 2 Vdevs Mirrored /Home-assistant/Media{{
now().strftime('%Y/%m/%d/%H-%M-%S') }}.mp4
target:
entity_id: camera.living_room
Things I’ve tried:
- I tried adding the following command into my configuration.yaml file:
homeassistant:
allowlist_external_dirs:
- /mnt/NAS 16TB 2 Vdevs Mirrored /Home-assistant/Media
However I got the following error:
"Logger: homeassistant.setup
Source: setup.py:275
First occurred: 4:19:24 PM (1 occurrences)
Last logged: 4:19:24 PM
Setup failed for ‘allowlist_external_dirs’: Integration not found."
- I’ve tried setting the path to:
/mnt/NAS 16TB 2 Vdevs Mirrored /Home-assistant/Media/.mp4
/NAS 16TB 2 Vdevs Mirrored /Home-assistant/Media/.mp4 - Tried changing the actions yaml to:
metadata: {}
data:
duration: 30
lookback: 0
filename: /mnt/NAS 16TB 2 Vdevs Mirrored /Home-assistant/Media{{now().strftime('%Y/%m/%d/%H-%M-%S') }}.mp4
target:
However I keep getting the “Error: Can’t write filename: /mnt/NAS 16TB 2 Vdevs Mirrored /Home-assistant/Media2025/02/22/16-28-58.mp4, no access to path!” error message.
Not sure what I’m doing wrong, or if this has nothing to do with truenas and is a home assistant, any help is appreciated!
