Hello, I am contacting this forum because the capacity of my pool has not increased after changing my three 6TB disks to 8TB disks (RAIDZ-1)
Current size : 10.77 TiB
Expected size : 14,56 TiB
Current OS : TrueNAS Scale ElectricEel-24.10.0.2
I expected it to do it automatically as I have read. Especially since TrueNAS detects changes in hard drive size.
I have been using TrueNAS for a short time and am having trouble diagnosing the problem. I saw an old topic on the old Truenas forum which talks about a similar problem but I would like confirmation of the problem before embarking on fairly long disk change operations and risking. (I have a 4th 8TB disk not used if necessary for manipulations )
Could anyone help me to describe what is the problem ? I share the results of some commands:
sudo lsblk -f
NAME FSTYPE FSVER LABEL UUID FSAVAIL FSUSE% MOUNTPOINTS
sda
└─sda1 zfs_member 5000 DATA 13695333462XXXXXXXXX
sdb
├─sdb1
├─sdb2 vfat FAT32 EFI 78E3-A95A
└─sdb3 zfs_member 5000 boot-pool 7999731742920588349
sdc
├─sdc1 linux_raid_member 1.2 truenas:swap0 03ccaf48-69f6-9f24-2fac-xxxxxxxxxxxx
└─sdc2 zfs_member 5000 DATA 13695333462XXXXXXXXX
sdd
├─sdd1 linux_raid_member 1.2 truenas:swap1 08e06a96-fce7-9a6a-f298-xxxxxxxxxxxx
└─sdd2 zfs_member 5000 DATA 13695333462XXXXXXXXX
sde
sudo parted -l
Model: ATA ST8000VN002-2ZM1 (scsi)
Disk /dev/sda: 8002GB
Sector size (logical/physical): 512B/4096B
Partition Table: gpt
Disk Flags:
Number Start End Size File system Name Flags
1 1049kB 8002GB 8002GB zfs data
Model: ATA CT240BX500SSD1 (scsi)
Disk /dev/sdb: 240GB
Sector size (logical/physical): 512B/512B
Disk Flags:
1 2097kB 3146kB 1049kB bios_grub, legacy_boot
2 3146kB 540MB 537MB fat32 boot, esp
3 540MB 240GB 240GB zfs
Model: ATA ST8000VX010-2ZR1 (scsi)
Disk /dev/sdc: 8002GB
Disk Flags:
1 1049kB 2149MB 2147MB swap
2 2150MB 6001GB 5999GB zfs
Model: ATA ST8000VX004-2M11 (scsi)
Disk /dev/sdd: 8002GB
Disk Flags:
Error: /dev/sde: unrecognised disk label
Disk /dev/sde: 240GB
Partition Table: unknown
Disk Flags:
sudo zpool status
pool: DATA
state: ONLINE
scan: resilvered 4.21T in 09:49:48 with 0 errors on Sat Nov 30 21:37:58 2024
NAME STATE READ WRITE CKSUM
DATA ONLINE 0 0 0
raidz1-0 ONLINE 0 0 0
30912e03-e40b-471b-af0e-xxxxxxxxxxxx ONLINE 0 0 0
315ac02f-195a-4d91-a00a-xxxxxxxxxxxx ONLINE 0 0 0
fefc624d-8ab2-428f-a606-xxxxxxxxxxxx ONLINE 0 0 0
errors: No known data errors
pool: boot-pool
state: ONLINE
scan: scrub repaired 0B in 00:00:30 with 0 errors on Mon Dec 2 03:45:31 2024
boot-pool ONLINE 0 0 0
sdb3 ONLINE 0 0 0
zpool get autoexpand DATA
NAME PROPERTY VALUE SOURCE
DATA autoexpand on local
