For some unknown reason, whenever I untoggle DHCP for my NIC it completely kills the connection, even though the default gateway (192.168.1.0/24) is set properly under General Settings. I have an alias set (192.168.1.8/32, the static IP I intend to use, which apparently sticks around even after toggling DHCP on) and that doesn’t work but the dynamic IP address given by DHCP (192.168.1.202) works without issue.
Once I disable DHCP pings aren’t received by 1.8 external to that device, but when I pull up the IPMI and ping 1.8 from within it responds and appears to be set properly. I only have 60 seconds to diagnose whats wrong before it refreshes so I’m not really sure what the issue is.
When I re-enable DHCP and try to ping the alias I get the following
[bran@r911vm89 Downloads]$ ping 192.168.1.8
PING 192.168.1.8 (192.168.1.8) 56(84) bytes of data.
From 192.168.1.202 icmp_seq=2 Redirect Host(New nexthop: 192.168.1.8)
From 192.168.1.202 icmp_seq=3 Redirect Host(New nexthop: 192.168.1.8)
From 192.168.1.202 icmp_seq=4 Redirect Host(New nexthop: 192.168.1.8)
--- 192.168.1.8 ping statistics ---
4 packets transmitted, 0 received, +3 errors, 100% packet loss, time 3051ms
It appears that the route isn’t being set when I disable DHCP. With it enabled it shows
truenas% ip route
default via 192.168.1.1 dev enp70s0f0
172.16.0.0/16 dev kube-bridge proto kernel scope link src 172.16.0.1
192.168.1.0/24 dev enp70s0f0 proto kernel scope link src 192.168.1.202
but when I disable DHCP all I see is
truenas% ip route
my network config:
[truenas] network configuration> config
| id | 1 |
| hostname | truenas |
| domain | local|
| ipv4gateway | 192.168.1.1 |
| ipv6gateway | |
| nameserver1 | 192.168.1.1 |
| nameserver2 | |
| nameserver3 | |
| httpproxy | |
| hosts | <empty list> |
| domains | <empty list> |
| service_announcement | <dict> |
| activity | <dict> |
| hostname_local | truenas |
| state | <dict> |
edit: yep, the issue is that it doesn’t re-apply the route. I quickly executed ip route add 192.168.1.0/24 dev enp7s0f0, and was able to bring up the webUI, login and commit it without issue.
