When I try to do the “make“ after clone the TrueNAS Scale code on my VM, I always get this problem:
2024-12-18 14:15:39] Updating of git repo ‘python3’ (using branch ‘master’) complete
[2024-12-18 14:15:40] Updating of git repo ‘truenas_audit_rules’ (using branch ‘master’) complete
[2024-12-18 14:18:40] Failed cmd ‘git clone --recurse
./sources/truenas’ with error ‘’ with returncode ‘128’. Check ‘git/truenas’ for details.
[2024-12-18 14:18:40] Retrying to checkout git repo ‘truenas’ (using branch ‘master’) (./logs/git/truenas.log)
[2024-12-18 14:19:13] Failed cmd ‘git clone --recurse ./sources/truenas’ with error ‘’ with returncode ‘128’. Check ‘git/truenas’ for details.
[2024-12-18 14:19:13] Retrying to checkout git repo ‘truenas’ (using branch ‘master’) (./logs/git/truenas.log)
[2024-12-18 14:24:01] Failed cmd 'git clone --recurse
./sources/kernel’ with error ‘’ with returncode ‘128’. Check ‘git/kernel’ for details.
[2024-12-18 14:24:01] Retrying to checkout git repo ‘kernel’ (using branch ‘truenas/linux-6.12’) (./logs/git/kernel.log)
And if I try to use the master branch, it shows like this:
bowen
18 hours ago
root@debian:/home/admin123/文档/test/scale-build# TRUENAS_BRANCH_OVERRIDE=“master” make iso
. ./venv-af1435d/bin/activate && scale_build iso
[2024-12-18 14:57:58] System state Validated
[2024-12-18 14:57:58] Manifest Validated
[2024-12-18 14:57:58] Dataset schema Validated
[2024-12-18 14:57:58] Data directory schema Validated
File “/home/admin123/文档/test/scale-build/venv-af1435d/bin/scale_build”, line 33, in
sys.exit(load_entry_point(‘scale-build==0.0.0’, ‘console_scripts’, ‘scale_build’)())
File “/home/admin123/文档/test/scale-build/venv-af1435d/lib/python3.11/site-packages/scale_build-0.0.0-py3.11.egg/scale_build/main.py”, line 92, in main
build_iso()
File “/home/admin123/文档/test/scale-build/venv-af1435d/lib/python3.11/site-packages/scale_build-0.0.0-py3.11.egg/scale_build/iso.py”, line 20, in build_iso
return build_impl()
File “/home/admin123/文档/test/scale-build/venv-af1435d/lib/python3.11/site-packages/scale_build-0.0.0-py3.11.egg/scale_build/iso.py”, line 30, in build_impl
if not os.path.exists(update_file_path()):
File “/home/admin123/文档/test/scale-build/venv-af1435d/lib/python3.11/site-packages/scale_build-0.0.0-py3.11.egg/scale_build/image/manifest.py”, line 79, in update_file_path
return os.path.join(RELEASE_DIR, f’TrueNAS-SCALE-{version or get_image_version()}.update’)
File “/home/admin123/文档/test/scale-build/venv-af1435d/lib/python3.11/site-packages/scale_build-0.0.0-py3.11.egg/scale_build/image/manifest.py”, line 71, in get_image_version
raise CallError(f’{RELEASE_MANIFEST!r} does not exist’)
scale_build.exceptions.CallError: ‘./tmp/release/manifest.json’ does not exist
make: *** [Makefile:33:iso] 错误 1
Could someone help me about this?
Thanks and BR,
Bowen
