If you’re not budget oriented, and are looking for a single-slot PCI-powered SFF GPU for transcoding, then this might be a good option for you.
I purchased it directly from Nvidia. I received mine today, plugged it in, and here are the results:
My software/hardware - Dragonfish-24.04.1.1 on an ASRock Rack X570D4U-2L2T
root@truenas:/home/admin# lspci -v | grep NVIDIA
2e:00.0 VGA compatible controller: NVIDIA Corporation Device 25b0 (rev a1) (prog-if 00 [VGA controller])
Subsystem: NVIDIA Corporation Device 1878
2e:00.1 Audio device: NVIDIA Corporation Device 2291 (rev a1)
root@truenas:/home/admin# nvidia-smi
Tue Jun 11 14:21:09 2024
| NVIDIA-SMI 545.23.08 Driver Version: 545.23.08 CUDA Version: 12.3 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| Fan Temp Perf Pwr:Usage/Cap | Memory-Usage | GPU-Util Compute M. |
| | | MIG M. |
| 0 NVIDIA Graphics Device Off | 00000000:2E:00.0 Off | N/A |
| 30% 47C P0 N/A / 50W | 1MiB / 8188MiB | 0% Default |
| | | N/A |
| Processes: |
| GPU GI CI PID Type Process name GPU Memory |
| ID ID Usage |
| No running processes found |
I haven’t tried it with any applications yet but it looks like it might work. Will keep you posted.
