Odd behavior of Qbitttorrent
  • I installed qbittorrent ,
  • i added in config dir (and configured by gui) the darktheme file
  • I restarted
  • and now i have 2 pods, one running and the other with http 500 error.
  • No web gui is redirect to me host node at specified port
HEEEEEELP!
Install TrueCharts qbit not TrueNAS, the truecharts one is far better
It’s been working fine on both the system I upgraded and a new Dragonfish install. I am using “Host Path” for both.
I uninstalled it since truecharts deprecated theirs. The issue I have with the truenas version is the inablity to add a vpn.
If I were you I would
  1. Install Jailmaker
  2. Spin up Docker
  3. Then launch your Qbit and with vpn as docker
You actually could as a custom app, but it’s not easy unless you are good with docker. You’d likely have to extend the standard docker image and make your own dockerfile to add in the vpn with something like supervisord. So, unless that’s easy for you, alternatives are a jail which also has some learning but has some good video or wait for Electric Eel where it should be simple or maybe a vm.
