Hi I’m trying to get everything working consistently for the following setup:
TrueNAS Core 13.0-U6.7
ix0 Intel 10gb interface, hardware offloading disabled, no IP
vlan for “main” traffic: vlan1, parent is ix0, no other settings, no IP
vlan for private traffic: vlan2, parent is ix0, no other settings, no IP
bridge1 with members vlan1 and vnet0, no other settings, IP 192.168.1.12/24
bridge2 with members vlan2, no other settings, IP 10.1.1.12
vnet0 for a Linux VM, the IP inside the VM is 192.168.1.13, vnet0 is in the tap group
Connection coming in to ix0 is tagged with vlanIDs 1 and 2, VMware ESX is connected with tagged 1 and 2 as well, everything else in the home network is untagged. The switch has the default/untagged VLAN set to 1. Wifi AP (Eero mesh) is connected to the core switch via an untagged port. There are no “vlan relearning” issues with the roaming AP connections since I’ve funneled all the APs through one managed port
Here’s the odd bit, everything works except for untagged clients. All VLAN2 traffic and connections work within. And all traffic for VLAN1 works from clients that pass through a trunked connection, such as VMs in ESX, or a mac on the untagged switch via the trunk uplink to the core switch. But wifi for instance can’t connect to 192.168.1.12, or it can for a minute or so, then goes back to “host is down” or just into the network black hole. What’s bizarre is that these same clients can connect to the Linux VM on vnet0, which is a member of bridge1 along with vlan1, 192.168.1.13. No problems there. Is there anything I’m missing with my setup? I’ve searched the historical community site and followed as much best practice as I could understand. I’m not a BSD networking guru but I’m fairly experienced with networking. This is got me scratching my head
Here’s my ifconfig
root@truenas[~]# ifconfig -a
re0: flags=8802<BROADCAST,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=8209b<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,WOL_MAGIC,LINKSTATE>
ether 18:c0:4d:87:79:cf
media: Ethernet autoselect (none)
status: no carrier
ix0: flags=8963<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=8138b8<VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,WOL_UCAST,WOL_MCAST,WOL_MAGIC,VLAN_HWFILTER>
ether a0:36:9f:1a:51:fc
media: Ethernet autoselect (10Gbase-T <full-duplex>)
status: active
options=680003<RXCSUM,TXCSUM,LINKSTATE,RXCSUM_IPV6,TXCSUM_IPV6>
inet6 ::1 prefixlen 128
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x3
groups: lo
pflog0: flags=0<> metric 0 mtu 33160
groups: pflog
vlan1: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
groups: vlan
vlan: 1 vlanproto: 802.1q vlanpcp: 0 parent interface: ix0
status: active
vlan2: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
groups: vlan
vlan: 2 vlanproto: 802.1q vlanpcp: 0 parent interface: ix0
status: active
bridge1: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
ether 58:9c:fc:00:23:21
inet 192.168.1.12 netmask 0xffffff00 broadcast 192.168.1.255
member: vnet0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 9 priority 128 path cost 2000000
member: vlan1 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 5 priority 128 path cost 2000
groups: bridge
bridge2: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
ether 58:9c:fc:00:0f:4d
inet 10.1.1.12 netmask 0xffffff00 broadcast 10.1.1.255
member: vlan2 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 6 priority 128 path cost 2000
groups: bridge
vnet0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=80000<LINKSTATE>
ether fe:a0:98:4b:27:dd
hwaddr 58:9c:fc:10:ff:c7
groups: tap
status: active
Opened by PID 1878
