Hi -
I just began receiving two alerts on one drive:
Device: /dev/ada2, 40 Currently unreadable (pending) sectors.
Device: /dev/ada2, 40 Offline uncorrectable sectors.
One time it was 48 sectors and now 40. I ran a long SMART test but don’t understand how to intepret the results. The disk is a SEAGATE IRONWOLF Pro 8TB. The disk is still under warranty.
Can someone help me understand what this means and if I should RMA the drive?
Thank you,
Dean
smartctl 7.2 2021-09-14 r5236 [FreeBSD 13.1-RELEASE-p9 amd64] (local build)
Model Family: Seagate IronWolf
Device Model: ST8000VN004-2M2101
Serial Number: WSD91YSV
LU WWN Device Id: 5 000c50 0e560bcd2
Firmware Version: SC60
User Capacity: 8,001,563,222,016 bytes [8.00 TB]
Rotation Rate: 7200 rpm
Form Factor: 3.5 inches
ATA Version is: ACS-4 (minor revision not indicated)
SATA Version is: SATA 3.3, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Wed Oct 30 13:20:23 2024 EDT
SMART support is: Enabled
See vendor-specific Attribute list for marginal Attributes.
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
been run.
data collection: ( 559) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 713) minutes.
Conveyance self-test routine
SCT capabilities: (0x50bd) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x000f 084 064 044 Pre-fail Always - 236548034
3 Spin_Up_Time 0x0003 083 083 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 43
5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 2088
7 Seek_Error_Rate 0x000f 079 060 045 Pre-fail Always - 21871895705
9 Power_On_Hours 0x0032 082 082 000 Old_age Always - 16586
10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 83
18 Head_Health 0x000b 100 100 050 Pre-fail Always - 0
187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0
188 Command_Timeout 0x0032 100 099 000 Old_age Always - 8590065666
190 Airflow_Temperature_Cel 0x0022 057 038 040 Old_age Always In_the_past 43 (Min/Max 34/44 #152)
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 46
193 Load_Cycle_Count 0x0032 100 100 000 Old_age Always - 780
194 Temperature_Celsius 0x0022 043 062 000 Old_age Always - 43 (0 22 0 0 0)
195 Hardware_ECC_Recovered 0x001a 084 064 000 Old_age Always - 236548034
197 Current_Pending_Sector 0x0012 099 099 000 Old_age Always - 632
198 Offline_Uncorrectable 0x0010 099 099 000 Old_age Offline - 632
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 16247h+56m+35.070s
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 25235616836
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 102084180156
SMART Error Log Version: 1
No Errors Logged
# 1 Short offline Completed without error 00% 16573 -
# 2 Extended offline Completed: read failure 90% 16563 4193936
# 3 Extended offline Aborted by host 90% 16535 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
