Old root pool spooks through the system
I am currently trying TrueNAS on an old computer and first named the pool “Test” and at some point I wanted to rename this to ‘tank’ as that seems to be the convention. So I deleted the old pool (Storage → Export/Disconnect → Delete Pool), and created a “tank” pool. This seems to have worked. So far so good.
Now as I said I am trying different things, and one of these is installing the “automatic-ripping-tool” App. Now I am getting this error notification during the deployment:
virt.global.setup emits [EFAULT] Failed to create dataset: Pool Test not found
I am assuming that somehow the deletion of the Test pool was not throughough. Of course a solution at this stage would be to wipe the system and start from scratch. But if I had more on the system this would not be a solution so I thought this may be useful as a bug report.
The full log is:
concurrent.futures.process._RemoteTraceback:
  File "/usr/lib/python3/dist-packages/middlewared/plugins/zfs_/dataset.py", line 141, in do_create
    with libzfs.ZFS() as zfs:
  File "libzfs.pyx", line 534, in libzfs.ZFS.__exit__
  File "/usr/lib/python3/dist-packages/middlewared/plugins/zfs_/dataset.py", line 142, in do_create
    pool = zfs.get(data['name'].split('/')[0])
  File "libzfs.pyx", line 1291, in libzfs.ZFS.get
libzfs.ZFSException: Pool Test not found
  File "/usr/lib/python3.11/concurrent/futures/process.py", line 261, in _process_worker
    r = call_item.fn(*call_item.args, **call_item.kwargs)
  File "/usr/lib/python3/dist-packages/middlewared/worker.py", line 116, in main_worker
    res = MIDDLEWARE._run(*call_args)
  File "/usr/lib/python3/dist-packages/middlewared/worker.py", line 47, in _run
    return self._call(name, serviceobj, methodobj, args, job=job)
  File "/usr/lib/python3/dist-packages/middlewared/worker.py", line 41, in _call
    return methodobj(*params)
  File "/usr/lib/python3/dist-packages/middlewared/schema/processor.py", line 52, in nf
    res = f(*args, **kwargs)
  File "/usr/lib/python3/dist-packages/middlewared/schema/processor.py", line 178, in nf
    return func(*args, **kwargs)
  File "/usr/lib/python3/dist-packages/middlewared/plugins/zfs_/dataset.py", line 149, in do_create
    raise CallError(f'Failed to create dataset: {e}')
middlewared.service_exception.CallError: [EFAULT] Failed to create dataset: Pool Test not found
The above exception was the direct cause of the following exception:
  File "/usr/lib/python3/dist-packages/middlewared/job.py", line 515, in run
    await self.future
  File "/usr/lib/python3/dist-packages/middlewared/job.py", line 560, in __run_body
    rv = await self.method(*args)
  File "/usr/lib/python3/dist-packages/middlewared/plugins/virt/global.py", line 297, in setup
    await self._setup_impl()
  File "/usr/lib/python3/dist-packages/middlewared/plugins/virt/global.py", line 502, in _setup_impl
    if (pool_name := (await self.setup_storage_pool(pool))) is not None:
  File "/usr/lib/python3/dist-packages/middlewared/plugins/virt/global.py", line 327, in setup_storage_pool
    await self.middleware.call('zfs.dataset.create', {
  File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1005, in call
    return await self._call(
  File "/usr/lib/python3/dist-packages/middlewared/main.py", line 720, in _call
  File "/usr/lib/python3/dist-packages/middlewared/service/crud_service.py", line 256, in create
    return await self.middleware._call(
  File "/usr/lib/python3/dist-packages/middlewared/main.py", line 728, in _call
    return await self._call_worker(name, *prepared_call.args)
  File "/usr/lib/python3/dist-packages/middlewared/main.py", line 734, in _call_worker
    return await self.run_in_proc(main_worker, name, args, job)
  File "/usr/lib/python3/dist-packages/middlewared/main.py", line 640, in run_in_proc
    return await self.run_in_executor(self.__procpool, method, *args, **kwargs)
  File "/usr/lib/python3/dist-packages/middlewared/main.py", line 624, in run_in_executor
Try go to Apps → Configuration and see if old pool Is still selected. In case just swap It to the new
This settinng was unfortunately already set to tank.
Curiously, this error message may in fact be unrleated to this app because I got it to work after all: In the log it complained about access and I realized that I had to give the apps users ownership over its config/log/etc. directories. I got the app to start now
Maybe there’s a similar setting to the app pool for virtual machines.
