Omada-Controller Docker Container Issue
Hi Everyone,
This is my first post to this forum.
I’ve updated my server from Truenas Scale 24.04 to 24.10.
After updating, I noticed that when I try to access the omada-controller gui using the WebUI button within Truenas Scale, I get this message.
Bad Request
This combination of host and port requires TLS.
What’s interesting is that if I try to manually type the IP address with port into the browser search bar using http:// I’ll get the bad request… message, but if I use https:// it works fine. When I use the webUI button within the docker compose Truenas apps window to open the web gui it shows the IP address and port without any http at all like all the other apps, but somehow it seems like omada app needs https to open unlike the other apps.
Not sure what is going on because I didn’t change any settings within Truenas since the update to 24.10 and it worked fine before the update. I have a few other apps and they can all access their web gui’s fine.
I have tried to uninstall omada-controller app and reinstall with no luck.
I tried running the omada app with the certificate field set to ‘none’ as opposed to using the default truenas certificate, with no luck.
I have tried running omada without ‘host network’ box checked with no luck.
I tried stopping nginx app and all port forwarding in case there may be some conflict, with no luck.
I turned off Pi-Hole and no luck.
The apps I currently have installed are:
dell-idrac-fan-controller
immich
nginx-proxy-manager
omada-controller
paperless-ngx
pihole
wg-easy
Any help would be greatly appreciated.
I’m happy to answer any questions you may have. Thank you
if you are working in save environment in a local network, try changing the port to plain http. You can check the port number while installing omada-controller (might be one digit lower than https, if installed with native settings).
Hope that will help.
Greetings
