I am building a DIY NAS for my small business.
The main objective of the NAS is for employees to backup media files (photos/videos/documents) and be able to access them quickly.
My hardware list is as follows
CPU: Amd Ryzen 5 4600G
RAM: 32 GB
HDD: 3x 4TB Ironwolf Pro
2.5’’ SSD: 1x 240GB
M.2 SSD: 1x 250GB
I will use the 3 HDD’s to create a storage pool.
What drive should I use as a boot drive between the 2.5’’ and the M.2?
Could one of the two SSD’s be used as a level 2 cache?
Would that even make sense?
Stux
Really depends on the specs of the two SSDs.
Do you know what they are?
I’d probably use the sata SSD as the boot drive.
The M.2 is a Kingston NV2 Gen 4x4 NVMe PCIe with rated read/write speeds of 3500/2800 MB/s
The 2.5" is a Kingston A400 SATA Rev. 3.0 with rated read/write speeds of 500/450 MB/s
etorix
4
With few drives it really doesn’t matter where to boot from. My preference generally goes to a NVMe drive, to spare a SATA port for data.
As for L2ARC, you should first use the system for some time and then run arc_summary to see whether a L2ARC could be of use.
MBILC
5
General rule is more system ram before a L2ARC device (starting around 64GB of ram first before considering a L2ARC)
Stux
6
IIRC, Optimizations were made to L2ARC tables when persistent L2ARC was developed, lowering the memory requirements.
