Passthrough PCIe Wireless Card
Hello all.
I’m playing around with Instances on Scale 25.04.1 and I’m looking for a way to pass through the wireless adapter on the motherboard to the VM. The GPU was passed through via the web UI options and seems to be working fine. When I attempt to add the wireless adapter, the VM refuses to start, citing some issue related to the aforementioned hardware. My Google-fu has proved insufficient to find a solution to this problem.
Neither I nor root can set a vfio override, and lspci lists neither a kernel driver nor kernel module in use for the wireless adapter.
Am I missing something? Some easy way to set this up in the web UI?
Thanks in advance.
Just wait for 25.04.2. Virtualization with libvirtd will be back.
Instances (Incus) will seemingly be deprecated.
So finding solutions for Instances (Incus) is a waste of time.
Truenas has 0 support for wifi so that seems about right, and correct me if I’m wrong but I read that they even specifically removed all wireless drivers and support from the kernel to keep people from using them. As far as passthrough I would also say yeah just wait for the return to classic virtualization and give it a shot there and see what happens.
TrueNAS itself doesn’t need to support WiFi, because PCIE passthrough is a lower level thing.
Check your IOMMU groups and ensure that the WiFi adapter is NOT inside a group with other devices. If the device is within a group with other devices, there can be many issues, like the one you described.
Here is a script I use to check the groups:
for g in /sys/kernel/iommu_groups/*; do
    echo "IOMMU Group ${g##*/}:"
    for d in $g/devices/*; do
        echo -e "\t$(lspci -nns ${d##*/})"
    done
done
What issue?
Please don’t have us guess.
fwiw i just tried passing through both my onboard intel ax210 and realtek 8125 (which has suddenly refused to work for truenas for some reason and been a big headache) to my win10 vm, the 8125 worked right away and windows automatically grabbed the ax210 drivers and then it started working too.
