PhotoPrism with mariadb on Scale 24.10
Hi, im new to scale, any knows how can i run photoprism with mariadb? sqlite gets to short to manage my library :frowning:
My version of truenas : ElectricEel-24.10.0.2
Thanks in advance!!
Maybe I’m wrong but this?
Hi, finally i get this working, i created a custom YAML , i install mariadb, photoprism and phpmyadmin to see what is happening on db :=)
services:
  mariadb:
    command: --innodb-buffer-pool-size=512M --transaction-isolation=READ-COMMITTED
      --character-set-server=utf8mb4 --collation-server=utf8mb4_unicode_ci --max-connections=512
      --innodb-rollback-on-timeout=OFF --innodb-lock-wait-timeout=120
    environment:
      MARIADB_AUTO_UPGRADE: '1'
      MARIADB_DATABASE: photoprism
      MARIADB_INITDB_SKIP_TZINFO: '1'
      MARIADB_PASSWORD: unseccure
      MARIADB_ROOT_PASSWORD: unseccure
      MARIADB_USER: photoprism
    image: mariadb:11
    restart: unless-stopped
    security_opt:
    - seccomp:unconfined
    - apparmor:unconfined
    stop_grace_period: 5s
    volumes:
    - dataset to store database:/var/lib/mysql
  phpmyadmin:
    image: phpmyadmin:latest
    ports:
    - 20801:80
    environment:
      PMA_HOST: mariadb:3306
      PMA_USER:  photoprism
      PMA_PASSWORD: unseccure
  photoprism:
    depends_on:
    - mariadb
    environment:
      PHOTOPRISM_ADMIN_PASSWORD: unseccure
      PHOTOPRISM_ADMIN_USER: user
      PHOTOPRISM_AUTH_MODE: password
      PHOTOPRISM_AUTO_IMPORT: -1
      PHOTOPRISM_AUTO_INDEX: 300
      PHOTOPRISM_BACKUP_ALBUMS: 'true'
      PHOTOPRISM_BACKUP_DATABASE: 'true'
      PHOTOPRISM_BACKUP_SCHEDULE: daily
      PHOTOPRISM_DATABASE_DRIVER: mysql
      PHOTOPRISM_DATABASE_NAME: photoprism
      PHOTOPRISM_DATABASE_PASSWORD: unseccure
      PHOTOPRISM_DATABASE_SERVER: mariadb:3306
      PHOTOPRISM_DATABASE_USER: photoprism
      PHOTOPRISM_DEFAULT_TLS: 'true'
      PHOTOPRISM_DETECT_NSFW: 'false'
      PHOTOPRISM_DISABLE_CHOWN: 'false'
      PHOTOPRISM_DISABLE_CLASSIFICATION: 'false'
      PHOTOPRISM_DISABLE_FACES: 'false'
      PHOTOPRISM_DISABLE_RAW: 'false'
      PHOTOPRISM_DISABLE_SETTINGS: 'false'
      PHOTOPRISM_DISABLE_TENSORFLOW: 'false'
      PHOTOPRISM_DISABLE_TLS: 'false'
      PHOTOPRISM_DISABLE_VECTORS: 'false'
      PHOTOPRISM_DISABLE_WEBDAV: 'false'
      PHOTOPRISM_EXPERIMENTAL: 'false'
      PHOTOPRISM_HTTP_COMPRESSION: gzip
      PHOTOPRISM_INDEX_SCHEDULE: ''
      PHOTOPRISM_LOG_LEVEL: info
      PHOTOPRISM_ORIGINALS_LIMIT: 5000
      PHOTOPRISM_RAW_PRESETS: 'false'
      PHOTOPRISM_READONLY: 'false'
      PHOTOPRISM_SIDECAR_YAML: 'true'
      PHOTOPRISM_SITE_AUTHOR: ''
      PHOTOPRISM_SITE_CAPTION: AI-Powered Photos App
      PHOTOPRISM_SITE_DESCRIPTION: ''
      PHOTOPRISM_SITE_URL: http://url:port/
      PHOTOPRISM_UPLOAD_NSFW: 'true'
    image: photoprism/photoprism:latest
    ports:
    - 20800:2342
    security_opt:
    stop_grace_period: 10s
    volumes:
    - pathtophotos:/photoprism/originals
    - pathtostorage:/photoprism/storage
    working_dir: /photoprism
  watchtower:
    environment:
      WATCHTOWER_CLEANUP: 'true'
      WATCHTOWER_POLL_INTERVAL: 7200
    image: containrrr/watchtower
    profiles:
    - update
    volumes:
    - /var/run/docker.sock:/var/run/docker.sock
    - ~/.docker/config.json:/config.json
I attach yaml here, and it helpos someone it will be coool :=)
This was exactly what I was looking for, thank you for sharing! I wondered why the official photoprism app for SCALE does not have an option for using mariadb - they should make it the default to avoid locking issues with SQLite (which I ran into).
One question though (I’m a SCALE beginner, but familiar with docker and docker-compose): I’d like to “combine” the official photoprism app with a self-written mariadb app (or an official one, once available). Doing that manually with compose was quite easy using docker-compose and networks.
Ideally I’d like to configure arbitrary containers within official stacks to not expose anything on the host or for other stacks while automatically getting official updates from upstream. Would that be a reasonable feature request? Another option would be some kind of namespace feature (networks?) where apps can see each other (getting a bit off-topic here…).
I’m struggling with the default Photoprism app - many database locks.
So i’d lke to follow your post and install it as a custom app. Never installed a custom app so i’d like to ask you if possible to enhace the explanations a bit for beginners :wink: what volumes need to be created, ports, if it passes the GPU.
A basic tutorial :slight_smile:
Thank you !
nvm… after trying for days to make this work and also getting photoprism to recognize more faces, i stumbled uppon Immich. Easy install, works very fast, uses the GPU and AI model for face recognition and it just recognised 4 times more faces then photoprism.
App works with mTLS from cloudflare, all good.
Happy camper now :slight_smile:
I am new to this, can you please explain a bit more how and where this script should be placed and executed?
If I already have photoprism installed on electric eel, will the mariadb script replace the sql, or do I need to reinstall photoprism?
Thanks a lot, it is definitely what I needed to make Photoprism run in a more optimal way.
Have you finetuned your configuration in the meantime? Any tips on making the system even faster/stable?
Thanks!
