After installing Pi-hole through Dockge, I’m receiving the following error message:
Error response from daemon: driver failed programming external connectivity on endpoint pihole (a22640277e9642371ad32271069be1a5c5591ca954aadcb316d19ab7c0b39684): failed to bind port 0.0.0.0:443/tcp: Error starting userland proxy: listen tcp4 0.0.0.0:443: bind: address already in use
I used the generic compose below:
services:
pihole:
container_name: pihole
image: pihole/pihole:latest
ports:
# DNS Ports
- 53:53/tcp
- 53:53/udp
# Default HTTP Port
- 80:80/tcp
# Default HTTPs Port. FTL will generate a self-signed certificate
- 443:443/tcp
# Uncomment the below if using Pi-hole as your DHCP Server
#- “67:67/udp”
# Uncomment the line below if you are using Pi-hole as your NTP server
#- “123:123/udp”
environment:
# Set the appropriate timezone for your location from
# List of tz database time zones - Wikipedia, e.g:
TZ: America/Chicago
# Set a password to access the web interface. Not setting one will result in a random password being assigned
FTLCONF_webserver_api_password: FancyPassword
# If using Docker’s default bridge network setting the dns listening mode should be set to ‘all’
FTLCONF_dns_listeningMode: all
# Volumes store your data between container upgrades
volumes:
- /Pool1/AppInstallFiles/DockgeConfigs/pihole/piholeconfig
# For persisting Pi-hole’s databases and common configuration file
- /Pool1/AppInstallFiles/DockgeConfigs/pihole/piholedns
# Uncomment the below if you have custom dnsmasq config files that you want to persist. Not needed for most starting fresh with Pi-hole v6. If you’re upgrading from v5 you and have used this directory before, you should keep it enabled for the first v6 container start to allow for a complete migration. It can be removed afterwards. Needs environment variable FTLCONF_misc_etc_dnsmasq_d: ‘true’
#- ‘./etc-dnsmasq.d:/etc/dnsmasq.d’
cap_add:
# See GitHub - pi-hole/docker-pi-hole: Pi-hole in a docker container
# Required if you are using Pi-hole as your DHCP server, else not needed
- NET_ADMIN
# Required if you are using Pi-hole as your NTP client to be able to set the host’s system time
- SYS_TIME
# Optional, if Pi-hole should get some more processing time
- SYS_NICE
restart: unless-stopped
networks: {}
Might you know what I’m doing wrong?
Thank you so much!
