Planning for replacing disks in RAIDZ1 pool
Hi
I’ve got a Scale system, that I’m using as hobbyist (Meaning downtime is acceptable). The main storage pool consists of a four wide RAIDZ1 VDEV that is populated with a mix of WD Red Plus and Seagate IronWolfs all 4TB and a set of 500GiB Samsung 980 NVMe’s as metadata VDEV (That I thought was a good idea, though I’m no longer convinced).
As I’m approaching capacity limit on my current pool I’ve bought 5 HGST Ultrastar He12 12TB drives (used) and the question now is, what’s the best migration strategy.
The rig is a Kaby Lake motherboard with an Broadcom 9207-8i SAS2308 6G SATA SAS HBA card to drive the spindles in the pool. Hence I could mount four of the new drives and copy data over, but I could also replace one disk at a time.
I’m reasonably happy with my current datasets and layout, so there’s no need as such to reshuffle anything.
Thanks in advance for any recommendations.
Your old drives aren’t that large, so replacing them one by one shouldn’t take too long. Make sure though to use in-place replacement, so you always keep your redundancy. The advantage of this method is that all your settings for that pool (e.g. periodic maintenance tasks, shares) are preserved.
On the other hand starting a new pool with 4 HDDs could be a good opportunity to get rid of that special VDEV, if you care to do that. It would also be an opportunity to adjust other parameters of your pool (e.g. recordsize), if you feel the need to do so.
Good considerations. I’ll put them on the list.
Thanks!
The one thing I forgot to mention in my previous post: One of the current (rather unfortunate) side-effects of the raidz expansion is that:
  1. The original data still uses the original ratio of data blocks to parity blocks and you’ll need to run a script for in-place rebalancing, if you want to reclaim that extra space.
  2. Currently the freespace calculation of some zfs tools are still based on the original data to parity ratio, so the freespace display in TrueNAS is likely not going to be accurate after a raidz expansion. However there are CLI commands that show the correct freespace amount.
You’re right that existing data aren’t rebalanced on RAIDZ widening, but I’m “only” talking about replacing all disks; one at a time to larger drives.
Unless I conclude that I made some error when building the pool in the first place that I need to replace it.
You did indeed, however you also raised the possibility of copying over data to a new 4-disk pool, which you’d then expand to 5 disks, didn’t you?
Whenever possible, avoid headaches by NOT using raidz expansion, and build a new pool instead at the desired width.
As raidz1 will become increasingly problematic with larger drives and increased width, this seems a good opportunity to move to 5-wide raidz2.
Sounds increasingly like the best path forward. I’ll take some time to study the nitty gritty details, such as ensuring that ashift really matches the physical sector size of the drives etc.
TrueNAS defailts to ashift=12 anyway. You don’t want to force ashift=9 on 512e drives, do you?
A 5-wide raidz2 pool would indeed be ideal, but the way I understood OP’s situation, they only have 4 SATA ports free at the moment. So without new hardware I don’t see how they can set up a new 5-wide pool without raidz expansion.
I still got free SATA ports on the motherboard. I think I can use those temporarily whilst migrating data to the new pool.
If the 4-wide goes away after migration, then it’s always possible to create the 5-wide with 4 disks and one sparse file, offline the sparse, migrate data with simple redundancy, then once migration has been confirmed and the old pool is gone, re-use one of the now free ports to plug in another drive and resilver, replacing the sparse file with a real disk.
That does require some CLI shenanigans as the GUI, wisely, doesn’t offer building vdevs with sparse files instead of disks :smiley: .
I would suggest a 5W RaidZ2 as well.
You only need to have 8 drives online to have redundancy of both pools still. Ie you can pull one of the new raidz2 drives and still transfer all your data to it.
But do you not have any motherboard sata ports available?
Use a motherboard SATA for a 9th port.
If there’s a hard limit at 8 ports: Export the old pool and unplug one of it drives. Plug in the new drives, create a 5-wide raidz2, then offline a drive and remove it. Plug then back the 4th drive of the old pool; replicate from the old pool to the (degraded) new pool (there’s still one degree of redundancy all along). Export and remove the old pool. Add the fifth drive and let the new pool resilver. Done—no expansion, no CLI shenanigans, no dragons.
I’ve got four vacant SATA slots on the mobo, so no drama at all.
I’d like to add another question, if I may. My goal is similar, i want to replace my disks one by one. My trouble tho is that I’m out of sata ports. So I considered attaching the new ones via USB and replace them over that interface. In the end, all six old disks will idle in sata while the new ones sit in an external USB cage. Here comes my question.
I’d like to then shutdown the system, open the server and detach the old drives, freeing up the sata ports in order to repopulate them with the new drives. The USB cage will then also be unplugged.
I assume truenas will complain that /dev/sdh turned into /dev/sdb and so forth. Will I be able to fix that easily?
TrueNAS tracks drives by UUID; changes in /dev/sdX numbering are irreleevant (and may occur at each boot).
The USB adapter trick is possible. I would do it with the new drive already on its final position, and the old drive in the USB enclosure: This way, there’s only one operation inside the case at each cycle, and the old drive can just be unplugged once the replacement is complete and the drive has been automatically offlined.
That’s a great idea. Thanks for the hint. I’ll report back.
Okay, I swapped out my internal hard drives (8TB) with the six new 12 TB ones, attaching the old sextett via USB. Now I don’t see the “offline” button for five out of six in my old pool.
comparing disk health
with lsblk
I see a lot of devices missing in the former. That a known issue with USB?
Edit: Since I’m a mad lad, I turned off the server, blindly removed one of the USB drives, bootet with a degraded pool and added one of the new drives. Works like a charm. At the current rate, I’ll be done by tuesday (within three days).
