Pool.dataset.sync_db_keys || failed to create mountpoint: Read-only file system Import was successful, but unable to mount some datasets#
Everything was working correctly, it was a reboot, it took a long time, I saw the log and they crossed it out! This error appears, leaving the system completely useless when it starts, luckily I had a backup of the configuration from two days ago and I will try to reinstall the system
Any other suggestions?
Can you start from the top?
  • What are you trying to do?
  • What did you already try?
  • System information?
  • Is ZFS encryption being used?
  • What is this pool?
  • Rotate images the correct orientation.
I don’t even know how it happened, I restarted the system and a Raidz1 stopped being recognized in the mount, I tried to mount it, unmount it, I did all kinds of commands and nothing, it appeared in the dataset but not in the storage, it appeared to import but it didn’t matter
Touching what I did was change the assembly
And right now at the end I mount it by removing the readonly=off and I am copying the data to delete the pool and copy it again correctly
I mean this with no disrespect, but can you understand how someone not in your position might have difficulty following along, let alone providing troubleshooting steps?
So everything’s “working correctly” now?
Here I leave all the threads that I was getting and testing to inform me of the error and I think that in the end in the last one I found the solution
http s://www. truenas .com/community/threads/unable-to-import-the-storage-pool-on-truenas-after-cut-power.115098/
http s://www. truenas .com/community/threads/zfs-pool-eror-checksum-and-gui-stuck.115163/
http s://www. truenas .com/community/threads/unable-to-view-or-mount-storage-pool-after-power-outage.83315/
http s://www. truenas .com/community/threads/unable-to-import-pool-after-version-upgrade.115158/
http s://www. truenas .com/community/threads/zfs-pool-corrupted.98445/
http s://www. truenas .com/community/threads/how-to-export-import-pools-from-cli-in-truenas-core.98309/
http s://docs. oracle .com/cd/E19253-01/819-5461/gazuf/index.html
http s://www. truenas .com/community/threads/unable-to-mount-full-zpool.45893/page-2
https://forum .proxmox .com/threads/zfs-pools-not-mounting-correctly.76810/
https:// davejansen .com/truenas-fix-cannot-mount-directory-failed-to-create-mountpoint/
“zfs readonly=on …” can be a problem, especially when the dataset has never been mounted before.
Usually, one the parent dataset with the readonly=on flag is the reason why the mountpoint fails because ZFS/FreeBSD needs to be able to write or edit the moutpoint details. At least this is rough understanding.
Can you elaborate as I suspect you are destroying a perfectly good pool.
Ensure ZFS mountpoints are correct:
zfs get mountpoint mypool
If needed, reset the mountpoint to /mnt/mypool:
zfs set mountpoint=/mnt/mypool mypool
