Pool degraded with very few usage
Hi everyone.
I have a true nas core x64 with 5 disks of 2tb each in a RAIDZ1 pool.
I turn on my nas very few times a month, like 2 times every 30 days. That is, I turn it on when my work PC is full and I have to move projects to the NAS.
What’s happening: last night I turn it on and something is wrong (slow and intermittent transfer), so I access its web page and see that it tells me Pool “DEGRADED” … enter the pool and see that the ada3 disk is “REMOVED”… I obviously panic. I don’t know what to do. But I see that at the top left it says SCANNING in progress and it gives me 3 hours to finish. So I let it do it.
This morning I access the nas web page and see that everything is online…
this thing doesn’t leave me calm, what can I do to be sure that my nas is OK and maintained? Can I launch some periodic command to make sure that everything is always in order?
I read in one of these topic that someone schedule a scrub and smar test. Are they right? or maybe can stressed up the nas and disks too much? Thanks.
Hello and welcome to the forums.
Can you please share your hardware specs and also the output of zpool status from the CLI?
Finally if you could post the output of smartctl -a /dev/ada3
Hi! Yeah of course i can share everything you need to help me but how i can do this?
  • hardware specs (is there a specific page that show me these info?)
  • output of zpool status from the CLI (how can i take this output?)
  • output of smartctl -a /dev/ada3 (how can i take this output?)
(I assembled my Nas a few years ago following the guide on the True Nas site, I’m not a disk and NAS expert, i’m sorry. But I settle in quickly and can follow directions.)
What hardware are you using? How are your drives connected? What drives are you using? Home Screen will give you some info about processor and RAM.
So you will do this via a shell session. Depending on what version of TrueNAS you are using you may or may not have an option within the UI. If not you will need to enable ssh and connect that way.
Thanks, ok lets go:
  1. This is a motherboard from a old PC Intel(R) Core™2 Duo CPU E8500
  2. CPU Highest Usage: 27%
  3. CPU Avg Usage: 16%
  4. Platform: Generic Version: TrueNAS-13.0-U5.3
  5. RAM: 7.9GiB total available Free: 4.4
  6. Disk 1 - 1.82TiB - WD20EFRX-68EUZN0
  7. Disk 2 - 1.82TiB - ST2000DM001-1ER164
  8. Disk 3 - 1.82TiB - ST2000DM008-2FR102
  9. Disk 4 - 1.82TiB - WD20EFRX-68EUZN0
  10. Disk 5 - 1.82TiB - ST2000DM008-2FR102
Yeah i have Shell in the web page UI, in the left menu. What commands should I give exactly?
See above
Yeah but what is CLI? and how i can get that output? thanks.
smartctl -a /dev/ada3 i think i’m able to get it:
root@NAS3[~]# smartctl -a /dev/ada3
smartctl 7.2 2021-09-14 r5236 [FreeBSD 13.1-RELEASE-p7 amd64] (local build)
Model Family: Seagate BarraCuda 3.5 (SMR)
Device Model: ST2000DM008-2FR102
Serial Number: WFL2YFDG
LU WWN Device Id: 5 000c50 0cc305c3d
Firmware Version: 0001
User Capacity: 2,000,398,934,016 bytes [2.00 TB]
Rotation Rate: 7200 rpm
Form Factor: 3.5 inches
TRIM Command: Available
ATA Version is: ACS-3 T13/2161-D revision 5
SATA Version is: SATA 3.1, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is: Sun Oct 6 14:19:12 2024 CEST
SMART support is: Enabled
General SMART Values:
was never started.
been run.
data collection: ( 0) seconds.
capabilities: (0x73) SMART execute Offline immediate.
command.
No Offline surface scan supported.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 199) minutes.
Conveyance self-test routine
SCT capabilities: (0x30a5) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x000f 083 064 006 Pre-fail Always - 180097910
3 Spin_Up_Time 0x0003 099 098 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 087 087 020 Old_age Always - 13919
5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 0
7 Seek_Error_Rate 0x000f 079 060 045 Pre-fail Always - 76002077
9 Power_On_Hours 0x0032 099 099 000 Old_age Always - 989h+49m+15.384s
10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 087 087 020 Old_age Always - 13909
183 Runtime_Bad_Block 0x0032 098 098 000 Old_age Always - 2
184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0
187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0
188 Command_Timeout 0x0032 100 100 000 Old_age Always - 2 2 2
189 High_Fly_Writes 0x003a 100 100 000 Old_age Always - 0
190 Airflow_Temperature_Cel 0x0022 069 048 040 Old_age Always - 31 (Min/Max 31/31)
191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 0
192 Power-Off_Retract_Count 0x0032 094 094 000 Old_age Always - 13657
193 Load_Cycle_Count 0x0032 090 090 000 Old_age Always - 20031
194 Temperature_Celsius 0x0022 031 052 000 Old_age Always - 31 (0 11 0 0 0)
195 Hardware_ECC_Recovered 0x001a 083 064 000 Old_age Always - 180097910
197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 855h+39m+15.468s
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 19070198649
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 33059871606
SMART Error Log Version: 1
No Errors Logged
1 Short offline Interrupted (host reset) 00% 988 -
2 Short offline Interrupted (host reset) 00% 986 -
3 Conveyance offline Completed without error 00% 637 -
4 Short offline Completed without error 00% 18 -
5 Short offline Completed without error 00% 1 -
1 0 0 Not_testing
2 0 0 Not_testing
ctrl+ins don’t let me copy all the output… do you know why?
Command Line Interface.
Yeah this can be a bit of a pain. Probably better to ssh in via something like putty if you’re using Windows or Terminal if on a Mac.
…I have a 100 TB pool ( show off ) and scrubbing takes 2 days.
But scrubbing is important as it tests each HDD and it will let you know, every month ( or whenever you schedule it ) if a HDD is getting iffy.
If you use that NAS box the way you describe it, the build in system ( that makes TrueNAS better than just an external USB drive ), can not check for failing hardware.
Also, store that NAS in a dry place. If you keep it on it stays moisture free but if is off, humidity can brake PCs more than usage.
I just wanted to bring this up as it is something to keep in mind :slight_smile:
Yeah I use it in this way becouse I tried many HDD box like icydock etc… with 4 bay or more, but, usb transfer was slowest then gigabit lan, and no raid possibility with those usb boxes. And also, the power management of those usb boxes was terrible for supply HDDs. When I powered off the boxes I remember that all disks make a terrible sounds because there were not a slow down spinning process. Just a hot power cut off.
I tried also many nas os before TrueNas. This is the one I love for easy of use and modern UI.
Anyway… today the ada3 is figured again as “REMOVED” … also today the NAS has make a resilver . But now sems it is performing a second resilver… again? Why?
I can’t perfrom the command to ada3… maybe becouse appear as “removed”
/dev/ada3: Unable to detect device type
Please specify device type with the -d option.
Use smartctl -h to get a usage summary
root@NAS3[~]#
this is ada2 for example…
FreeBSD 13.1-RELEASE-p7 n245428-4dfb91682c1 TRUENAS
        TrueNAS (c) 2009-2023, iXsystems, Inc.
        All rights reserved.
        TrueNAS code is released under the modified BSD license with some
        files copyrighted by (c) iXsystems, Inc.
        For more information, documentation, help or support, go here:
        http://truenas.com
Welcome to TrueNAS
Warning: the supported mechanisms for making configuration changes
are the TrueNAS WebUI and API exclusively. ALL OTHERS ARE
NOT SUPPORTED AND WILL RESULT IN UNDEFINED BEHAVIOR AND MAY
RESULT IN SYSTEM FAILURE.
root@NAS3[~]# smartctl -a /dev/ada2
Model Family:     Seagate Barracuda 7200.14 (AF)
Device Model:     ST2000DM001-1ER164
Serial Number:    Z4ZCPNTH
LU WWN Device Id: 5 000c50 0b4dbf71e
Firmware Version: CC28
ATA Version is:   ACS-2, ACS-3 T13/2161-D revision 3b
Local Time is:    Mon Oct  7 07:51:46 2024 CEST
Offline data collection status:  (0x82) Offline data collection activity
                                        was completed without error.
                                        been run.
data collection:                (   80) seconds.
capabilities:                    (0x7b) SMART execute Offline immediate.
                                        command.
                                        power-saving mode.
recommended polling time:        ( 216) minutes.
SCT capabilities:              (0x1085) SCT Status supported.
  1 Raw_Read_Error_Rate     0x000f   115   099   006    Pre-fail  Always       -       85312696
  3 Spin_Up_Time            0x0003   096   095   000    Pre-fail  Always       -       0
  4 Start_Stop_Count        0x0032   100   100   020    Old_age   Always       -       190
  7 Seek_Error_Rate         0x000f   072   060   030    Pre-fail  Always       -       17961673
  9 Power_On_Hours          0x0032   099   099   000    Old_age   Always       -       988
 12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       177
183 Runtime_Bad_Block       0x0032   100   100   000    Old_age   Always       -       0
188 Command_Timeout         0x0032   100   100   000    Old_age   Always       -       0 0 0
189 High_Fly_Writes         0x003a   093   093   000    Old_age   Always       -       7
190 Airflow_Temperature_Cel 0x0022   068   049   045    Old_age   Always       -       32 (Min/Max 22/32)
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       75
193 Load_Cycle_Count        0x0032   100   100   000    Old_age   Always       -       544
194 Temperature_Celsius     0x0022   032   051   000    Old_age   Always       -       32 (0 8 0 0 0)
240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       922h+54m+00.085s
241 Total_LBAs_Written      0x0000   100   253   000    Old_age   Offline      -       17215653685
242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -       92150140791
No Errors Logged
# 1  Short offline       Completed without error       00%       967         -
# 2  Conveyance offline  Completed without error       00%       620         -
# 3  Short offline       Completed without error       00%        11         -
# 4  Short offline       Completed without error       00%         0         -
root@NAS3[~]#
root@NAS3[~]# >....
No Errors Logged
root@NAS3[~]# >....
No Errors Logged
The situation right now, 7:51am
I don’t know how to help. Am new at this but, I’d shutdown, swap the cables from that drive with another to remove the possibility that is related to the controller or port or sulfidation of the contacts or power to that drive.
My guess is that the drive is not seen, as if not connected.
Because is rare for it to be just a software issue without the HDD not having an issue first.
oh my… the resilver is restarting again after reach the 100%.
I shut down the nas to check the cable of disk 3.
It take some time to shutting down this time.
The cable is ok… it is in a location that no one can move or touch it.
I try to power on.
Nothing. The ada3 is removed and the resilvering is starting from where it remain befor the shut down. Can i interrupt the resilvering now, shutting down the nas and replacing the disk with new one? or may i have to wait… or perform some command?
Hello @Awesome_One
It seems that you performed only short S.M.A.R.T. tests.
Be sure to perform these two actions:
1. Check Hard disks: Take long S.M.A.R.T. test, not a short one. It will take several hours, but it will test them thoroughly. You can do this
  • from graphical user interface: Storage → Disks → select drive(s) → Manual test → Long
  • from command line interface: smartctl -t long /dev/ada3
After that, you can check the results with smartctl -a /dev/ada3
2. Check (and correct) file system: You can do this
  • from graphical user interface: Storage → Pools → Gear icon → Scrub pool
  • from command line interface: zpool scrub Disco_1
After that, you can check the results with zpool status Disco_1
Whatever the results are, RAIDZ1 provides enough level of redundancy, so you can buy a new disk and replace without loosing the data. In fact - that’s why we are using TrueNAS. :sunglasses:
Hi @jaleksic … in Disk page sems it literalli miss the Disk number 3…
in the pool page insteas you can see this situation:
What suggest to do first? thanks.
Yes,the server does not see it. There’s either connection problem or the disk failed.
Shut down the computer and check the cables - both power and data. If after that the disk is still missing, then it failed. In that case replace it with a new one. As I said, your configuration (RAIDZ1) allows you to do this without loosing the data.
Check your sata cable of that drive.
