could maybe someone guide me on how to proceed ![]()
after power outage the pool with my APPS became offline.
it was installed on the same ssd physical disc as the boot-pool (truenas system).
but all it had inside was wireguard app for remote connections.
i had these alerts:
Failed to configure kubernetes cluster for Applications: Missing “APPS/ix-applications/k3s, APPS/ix-applications/releases” dataset(s) required for starting kubernetes.
Device: /dev/sda [SAT], 2 Currently unreadable (pending) sectors.
Failed to configure kubernetes cluster for Applications: Missing “APPS/ix-applications/releases, APPS/ix-applications/k3s” dataset(s) required for starting kubernetes.
in the tests the disk itself seems to be ok.
when i list the pools in the shell its not there anymore and i cannot import it.
is there a way to somehow restore the pool ?
should i just delete the pool and then create a new one to store wireguard ?
or is there a more rational place to put this one specific app?
Thanks in advance
1 Extended offline Completed without error 00% 18624 -
2 Extended offline Completed without error 00% 18610 -
3 Short offline Completed without error 00% 18610 -
4 Short offline Completed without error 00% 18602 -
Model Family: Intel 53x and Pro 1500/2500 Series SSDs
Device Model: INTEL SSDSC2BW120A4
Serial Number: PHDA4350046A1207GN
LU WWN Device Id: 5 5cd2e4 04ba32b86
Firmware Version: DC32
User Capacity: 120,034,123,776 bytes [120 GB]
Sector Size: 512 bytes logical/physical
Rotation Rate: Solid State Device
TRIM Command: Available, deterministic
Device is: In smartctl database 7.3/5319
ATA Version is: ACS-2 (minor revision not indicated)
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Wed May 28 14:04:00 2025 EEST
SMART support is: Enabled
General SMART Values:
Offline data collection status: (0x02) Offline data collection activity
was completed without error.
been run.
data collection: ( 2930) seconds.
capabilities: (0x7f) SMART execute Offline immediate.
Abort Offline collection upon new
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 48) minutes.
Conveyance self-test routine
SCT capabilities: (0x0025) SCT Status supported.
SCT Data Table supported.
5 Reallocated_Sector_Ct 0x0032 100 100 000 Old_age Always - 0
9 Power_On_Hours_and_Msec 0x0032 100 100 000 Old_age Always - 18627h+14m+49.100s
12 Power_Cycle_Count 0x0032 098 098 000 Old_age Always - 2581
170 Available_Reservd_Space 0x0033 100 100 010 Pre-fail Always - 0
171 Program_Fail_Count 0x0032 100 100 000 Old_age Always - 0
172 Erase_Fail_Count 0x0032 100 100 000 Old_age Always - 0
174 Unexpect_Power_Loss_Ct 0x0032 100 100 000 Old_age Always - 58
183 SATA_Downshift_Count 0x0032 100 100 000 Old_age Always - 0
184 End-to-End_Error 0x0033 100 100 090 Pre-fail Always - 0
187 Uncorrectable_Error_Cnt 0x0032 100 100 000 Old_age Always - 0
190 Airflow_Temperature_Cel 0x0032 028 039 000 Old_age Always - 28 (Min/Max 16/39)
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 58
199 UDMA_CRC_Error_Count 0x0032 100 100 000 Old_age Always - 0
225 Host_Writes_32MiB 0x0032 100 100 000 Old_age Always - 716789
226 Workld_Media_Wear_Indic 0x0032 100 100 000 Old_age Always - 65535
227 Workld_Host_Reads_Perc 0x0032 100 100 000 Old_age Always - 59
228 Workload_Minutes 0x0032 100 100 000 Old_age Always - 65535
232 Available_Reservd_Space 0x0033 100 100 010 Pre-fail Always - 0
233 Media_Wearout_Indicator 0x0032 070 070 000 Old_age Always - 0
241 Host_Writes_32MiB 0x0032 100 100 000 Old_age Always - 716789
242 Host_Reads_32MiB 0x0032 100 100 000 Old_age Always - 1061095
249 NAND_Writes_1GiB 0x0032 100 100 000 Old_age Always - 97894
