My TuneNAS Scale box has droped it main data pool after upgrading to 25.10.4. It is comprised of 8x drives in a Z2 configuration and all 8 drives are not visible in TrueNAS. During boot, all 8 drives are detected by the HBA Card. I tried to disconect and re-import without deleting the data and configuration and no option to re-import the pool shows up.
Here are the specs of the System:
Intel Xeon(R) E-2136.
Kingston 32 GB ECC RAM.
Supermicro X11SCL-F.
LSI SAS 9207-8i HBA card IT mode (FW 20.00.07.00-IT).
Seasonic SS-400L2U PSU.
Silverstone RM212 Case.
Boot drive is a no-name Amazon (Dogfish) 64gb M.Sata.
4 other drive are connected to the motherboard’s onboard SATA header via a Reverse SAS breakout cable from the backplane. No issues with thoes drives.
So far swithching back to the previous boot (25.10.3.1 or 25.04.2.6) yeilded no results.
Replacing the cables with a working spares yeilds no result.
Swaping the card into other pci slots does nothing.
HBA card is listed in lspci.
Back at the begining of April I upgraded from Core to Scale (Fresh install with imported config).
I dont have much experience in this and do not know where to go from here but I dont think the dives are bad.
