Hardware: 2 x EPYC 7532 (64 cores), 512Gb ram, HBA connection to JBOD enclosure.
Configuration:
8x4TB in pool as 4 x MIRROR | 2 wide | 3.64 TiB.
4x1TB (nvme) in pools as 1 x MIRROR | 4 wide | 894.25 GiB
Would I be better (for performance) for the nvme to have them as 2 x mirror 2 wide?
Let me apologies now for the next question . . . which is a perennial “ask”
I have configured my second pool with a Zvol of 698.85GB (81.2%). Then created an iSCSI share of 500GB.
While I’ve read older and newer posts provisioning storage seems tricky - as I presume part of the problem is one size doesn’t fit all?
I’d appreciate thoughts on the Zvol size - should I better sliding just under 80% or go much lower?
Does the provisioned size of the iscsi come into play or is that irrelevant in relation to zvol size.
No experience here either but the 50% guidance is for HDDs, to prevent excessive fragmentation; SSDs, being much better at random access, should be able to go over that, but you’re on your own to find out what would be the practical limit.
Note: it has to do with the cost of a seek. As such, SSDs may obviate the problem.
ALSO, the above link shows why 90% is an issue, but more so above 90% (or is it 95%) utilization ZFS changes it’s free space finding algorithm, which further slows you down.
