Possibility of naming rsync tasks
Problem/Justification
It is not possible to name rsync tasks. Therefore in the list of tasks, it is not possible to know what task does what. If I need to run a task manually, I need to go through each and click Edit to see properties of task and find the correct one.
Impact
It will be eays to know which rsync task is the one you are looking for by only looking at the list instead of opening each of them to find the correct one.
User Story
A user wants to run a rsync task. He can immediately find the task by looking at (the new) name column in the list. He then clicks the … and runs it immediately.
Aren’t you filling in the Description section? Then just adjust the Columns to show that info. It’s shown in the documents in the Rsync Tasks screen on the right. Click Columns and then check or uncheck depending on what you want showing
Yes, I have filled description, and I see now that in the full screen view of Rsync tasks I can see this column. So that helps a bit. But even better would have been to be able to see this column in the widget directly without changing view.
