Does it make a big difference if the cache is mismatched?
Also I wanted to ask, if it’s possible to reboot the NAS during the expansion process or is there a chance that the data will be lost?
I don’t think the cache sizes mismatching will make a difference.
And I believe I read here that expansion will restart where it left off after a reboot.
Mine has been running for 38 days now and is only up to 55% completed…
And once this drive is done being added, I have another one to add…
So about 4 months to expand 2 disks… Crazy
root@truenas[~]# zpool status data
pool: data
state: ONLINE
scan: resilvered 3.90T in 16:53:25 with 0 errors on Mon Nov 4 10:49:32 2024
expand: expansion of raidz1-0 in progress since Fri Nov 1 17:43:17 2024
9.14T / 16.4T copied at 2.71M/s, 55.60% done, (copy is slow, no estimated time)
NAME STATE READ WRITE CKSUM
data ONLINE 0 0 0
raidz1-0 ONLINE 0 0 0
e077b967-57eb-4cb5-abb2-149d99dfdae0 ONLINE 0 0 0
b7683a54-6aff-8b45-b68b-0e7fd4361d93 ONLINE 0 0 0
d8390cb5-0673-3742-a323-f8bd762ea8ec ONLINE 0 0 0
13178070-5ded-1a42-ab01-950485d986be ONLINE 0 0 0
473195e3-0769-4497-ae57-c9720ed5278d ONLINE 0 0 0
alright, thanks!
Yeah, I read that too, but I don’t want to take that risk so I will let it finish first.
that’s very slow - 23.68% after 13 days here. Are your disks smr or cmr?
Read above… There’s one SMR drive in the mix.
What are the exact models of your disks? Are they SMR disks?
After reading this thread I’m quite happy with my ~8 days of expanding at ~50-55MB/s.
I already thought that was slow…
They are all Western Digital Red 6TB drives… but now that i am looking at the specific model numbers and cross references their specs:
I have 4 WD60EFAX drives (SMR) in the pool now… but the one i am adding to the pool to expand is WD60EFRX (CMR)
Very very very bad news. I know it will be expensive, but you really really need to consider replacing all the EFAX drives with EFRX ones.
What’s the benefit i would see? I don’t have any complaints around speed/performance and have seen no reliability issues either. Would swapping all the drives only benefit me during this expansion process (essentially a one time operation as i max out the bays)
You don’t have any complaints about performance YET, but if you ever need to resilver or you want to expand the pool, you will definitely have complaints about performance, but more importantly during a resilver the stress on the remaining drives will be 10x longer than if they were CMR drives, and the risks of you losing another drive and thus your entire pool during the resilver will be substantially higher.
But these are your drives, your data, your risk, and it is entirely up to you how much risk of losing your pool completely that you are prepared to take.
P.S. With 24TB usable space, most of the experienced people here would probably have gone for RAIDZ2. But you cannot change it once it is set, so like me - I made the same decision with my 5x 4TB CMR disks - you are stuck with RAIDZ1 and associated risks now (but bigger disks and more data and added SMR).
Thanks for the information. I don’t really know what SMR vs CMR means. I’ll have to do some research to understand how to compare these technologies and what it means. From your context I gather that CMR > SMR in some ways.
At the time of my build I had 4 drives on a budget and double parity would have not yielded me enough usable capacity so I opted for single partity (with the associated risk). Luckily this is just a home lab and everything is backed up off-site nightly so i’m not overly worried about loss in the event of a 2 drive failure. It would suck… don’t get me wrong… but I would recover eventually.
I recently was gifted 6 of these CMR drives and decided to add them to my 6-bay NAS to max out my bays and expand capacity, but since i have enough of them I can go through and swap each of the SMR’s for the CMRs I now have. Of course i don’t want to try to replace a drive while the expansion is going… So i’ll have to wait a month at this point for it to finish i suppose.
Well the expansion may not take a month. It might be a bit less, it might error out part way through.
In another thread, someone’s new SMR drive errored out during expansion, and the choice was to resilver that drive first when it was only partly expanded or to clear the error and let it continue (possibly needing to do that several times). The consensus (for a pool with all CMRs except for the one SMR that had faulted) was to replace the SMR with a CMR, resilver it, and then let the expansion complete.
Your situation is a bit different because you have multiple SMR drives in the pool, and the expansion has not errored out. But I think you still have a choice:
I have literally no idea which would be best.
This is a good topic.
I had the same issue, extending the pool with 4th disk crawling with 3-4MBps which is insanely slow. It would’ve taken 1 month to extend the zpool. Taking into consideration that the pool is consistent of only CMR drives (WD DC Ultrastar)
First it was like this after progressing the whole night.
pool: silo
state: ONLINE
scan: resilvered 4.42T in 1 days 08:07:49 with 0 errors on Wed May 7 18:03:59 2025
expand: expansion of raidz1-0 in progress since Wed May 7 18:44:55 2025
186G / 13.3T copied at 4.16M/s, 1.36% done, (copy is slow, no estimated time)
silo ONLINE 0 0 0
1ee7c057-25d7-4522-8887-b72d36d0f61d ONLINE 0 0 0
5c55be94-d27f-4f99-9bbf-8bf2005e2d15 ONLINE 0 0 0
280e6cc8-15ab-4f75-803b-59865ffafbd1 ONLINE 0 0 0
007f8070-c8ce-4d94-8c16-42bcd9f25dff ONLINE 0 0 0
errors: No known data errors
Then I read one of the comments and verified the cache values myself:
# for disk in /dev/sd?; do; hdparm -W $disk; done
/dev/sda:
write-caching = 0 (off)
/dev/sdb:
/dev/sdc:
/dev/sdd:
/dev/sde:
write-caching = 1 (on)
I enabled the write-caching for all data drives to see if it makes any difference:
# sudo hdparm -W 1 /dev/sdb
/dev/sdb:
setting drive write-caching to 1 (on)
Surely this seems to resolved the slow extending issue:
# zpool status silo
pool: silo
state: ONLINE
2.73T / 13.3T copied at 40.5M/s, 20.44% done, 3 days 04:25:38 to go
silo ONLINE 0 0 0
It’s now at 40.5M/s and growing ![]()
Thanks to all the comments in this topic!
Nice thread! Now I can track the progress
And I was able to verify write-cache! Thx!
pool: data2
state: ONLINE
expand: expansion of raidz1-0 in progress since Sat Aug 2 15:14:23 2025
761G / 24.5T copied at 386M/s, 3.04% done, 17:54:00 to go
data2 ONLINE 0 0 0
c35f07e6-1a5d-492f-85c0-de75b033f213 ONLINE 0 0 0
f066da66-8c78-4c82-9d22-b1889a91204f ONLINE 0 0 0
f025156c-fa3c-4530-8dc2-1a7eddd06689 ONLINE 0 0 0
1ec673d8-190a-4132-8868-d1e5b4d10480 ONLINE 0 0 0
Though, I have a question: Is it safe to use the pool while extending? Or should I stop writing or reading data?
It’s safe to use the pool
