I’m trying to migrate a bunch of data from a QNAP NAS that is running QuTS Hero (based on ZFS) to TrueNAS SCALE (running TrueNAS SCALE 24.04.2.2). I have done a zfs send on snapshots from the QNAP with:
zfs send -v zpool1/zfs1@migrate3 > zfs1.snapshot
zfs send -v zpool1/zfs2@migrate3 > zfs2.snapshot
When I try and receive the first snapshot into TrueNAS (using a test pool with just one device for now) I get:
# zfs receive -dv temp-pool/restore < zfs1.snapshot
receiving full stream of zpool1/zfs1@migrate3 into temp-pool/restore/zfs1@migrate3
cannot open 'temp-pool/restore/zfs1': dataset does not exist
cannot receive new filesystem stream: dataset does not exist
Maybe I have misunderstood the -d parameter here, but I expected that to create the dataset for me? No problem I thought, so I did:
# zfs create temp-pool/restore/zfs1
# zfs receive -d temp-pool/restore < zfs1.snapshot
cannot receive new filesystem stream: destination 'temp-pool/restore/zfs1' exists
must specify -F to overwrite it
Hmmm…
# zfs receive -Fd temp-pool/restore < zfs1.snapshot
OK, maybe there’s an issue with that snapshot. Let’s try the 2nd one:
# zfs receive -d temp-pool/restore < zfs2.snapshot
cannot receive new filesystem stream: invalid backup stream
I’ve tried using zstreamdump on both files and they seems OK:
# zstreamdump zfs1.snapshot
BEGIN record
hdrtype = 1
features = 4
magic = 2f5bacbac
creation_time = 671143b5
type = 2
flags = 0x4
toguid = d514a22751804d40
fromguid = 0
toname = zpool1/zfs1@migrate3
payloadlen = 0
END checksum = 1b596bb27ecc14d/b67978c902fbec9c/9c38850172e55d54/45db71b2243a1710
SUMMARY:
Total DRR_BEGIN records = 1 (0 bytes)
Total DRR_END records = 1 (0 bytes)
Total DRR_OBJECT records = 1589 (268944 bytes)
Total DRR_FREEOBJECTS records = 327 (0 bytes)
Total DRR_WRITE records = 3764 (322710016 bytes)
Total DRR_WRITE_BYREF records = 0 (0 bytes)
Total DRR_WRITE_EMBEDDED records = 1 (0 bytes)
Total DRR_FREE records = 1825 (0 bytes)
Total DRR_SPILL records = 1 (4096 bytes)
Total records = 7509
Total payload size = 322983056 (0x13405490)
Total header overhead = 2342808 (0x23bf98)
Total stream length = 325325864 (0x13641428)
# zstreamdump zfs2.snapshot
BEGIN record
hdrtype = 1
features = 4
magic = 2f5bacbac
type = 2
flags = 0x0
toguid = 3907ba4a0ea7cfce
fromguid = 0
toname = zpool1/zfs2@migrate3
payloadlen = 0
END checksum = 2c97cd94a9b83c/b9929659c7ac52f6/8ba3ff2da7907548/f12af225a109af94
SUMMARY:
Total DRR_OBJECT records = 251 (41704 bytes)
Total DRR_FREEOBJECTS records = 51 (0 bytes)
Total DRR_WRITE records = 487 (38205952 bytes)
Total DRR_WRITE_EMBEDDED records = 0 (0 bytes)
Total DRR_FREE records = 305 (0 bytes)
Total DRR_SPILL records = 0 (0 bytes)
Total records = 1096
Total payload size = 38247656 (0x2479ce8)
Total header overhead = 341952 (0x537c0)
Total stream length = 38589608 (0x24cd4a8)
My initial suspicion was that QNAP’s ZFS implementation had some changes that made it incompatible, but I think the zstreamdump output suggests otherwise?
I don’t have a huge amount of experience with ZFS, so would appreciate any pointers on other things to try! I still have access to the original data so can always regenerate the snapshot stream if necessary. If the worst comes to the worst I can always do an rsync instead, but I’m hoping to avoid that if I can.
Thanks,
Neil
