I have a really weird issue with a LSI 9300-8i.
In my server are three HBAs, all same type 9300-8i and firmware (16.00.12.00), 24 Samsung SATA SSDs connected to them.
Actually running on Core 13.0-U6.7, everything is fine for several years.
When I update to Scale 25.04.2.1 (clean install with different boot drives) only 2 of 3 LSI 9300-8i are working.
I get following messages during boot:
mpt3sas_cm2: doorbell handshake int failed
mpt3sas_cm2: _base_send_ioc_init: handshake failed
mpt3sas_cm2: fault info from func: mpt3sas_base_check_for_fault_and_issue_reset
mpt3sas_cm2: fault state(0x0820)!
When I switch back to Core, everything ist working again flawlessly, no errors.
I tried to switch PCIe slots, but it is always the same HBA which does not work.
What is going on here? Why is the same HBA working with Core/FreeBSD but not with Scale/Debian?
And why are the other two identical controllers with identical firmware working both on Core and Scale?
