Hi everyone, I have started to use Truenas Scale since a couple of weeks now, but there is 1 thing I can’t seem to find a way.
Last week I installed a new NIC (intel X710 with 2 SFP+ ports of course) and I want to setup new VLANs. I have a gateway in my home (ubiquiti UDM SE) and the 2 SFP+ ports are of course attached to my truenas scale server.
- Port1 (only has native vlan3 and other vlans are blocked) → this is the port that gives truenas scale the IP (which is correct)
- Port2 (native vlan2, and tagged vlan6 and vlan7)
At the moment Port1 gets an IP from vlan3 (correct) and Port2 get IP from vlan2 (also correct). As soon as I try to create a vlan and attach it to use port2 as interface, the test starts but changes are rolled back and I can’t understand why.
The only “strange” thing I noticed, is that before applying changes I get prompted to add a gateway IP and here I have tried to use gateway of vlan3, gateway of vlan2 and also gateway of vlan6, but in all cases I get this error → 192.168.XX.1 is not reachable from any interface on the system.
Can someone help, please?
