Problems after HDD replacement
some weeks ago I had to replace one hard drive in my pool. (zpool2 with 5 drives) All this was not a problem.
But after replacement I saw a error message
After zpool clear all errors are gone and
mynas001# smartctl -a /dev/ada4
smartctl 7.2 2021-09-14 r5236 [FreeBSD 13.1-RELEASE-p9 amd64] (local build)
Device Model: WDC WD161KFGX-68AFPN0
Serial Number: 2PHRT9NT
LU WWN Device Id: 5 000cca 2c1d872ee
Firmware Version: 83.00A83
User Capacity: 16,000,900,661,248 bytes [16.0 TB]
Rotation Rate: 7200 rpm
Form Factor: 3.5 inches
Device is: Not in smartctl database [for details use: -P showall]
ATA Version is: ACS-4 published, ANSI INCITS 529-2018
SATA Version is: SATA 3.3, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Sun May 12 12:01:01 2024 CEST
SMART support is: Enabled
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
been run.
data collection: ( 101) seconds.
capabilities: (0x5b) SMART execute Offline immediate.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: (1844) minutes.
SCT capabilities: (0x003d) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x000b 100 100 001 Pre-fail Always - 0
2 Throughput_Performance 0x0004 136 136 054 Old_age Offline - 96
3 Spin_Up_Time 0x0007 097 097 001 Pre-fail Always - 141
4 Start_Stop_Count 0x0012 100 100 000 Old_age Always - 2
5 Reallocated_Sector_Ct 0x0033 100 100 001 Pre-fail Always - 0
7 Seek_Error_Rate 0x000a 100 100 001 Old_age Always - 0
8 Seek_Time_Performance 0x0004 140 140 020 Old_age Offline - 15
9 Power_On_Hours 0x0012 100 100 000 Old_age Always - 547
10 Spin_Retry_Count 0x0012 100 100 001 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 2
22 Unknown_Attribute 0x0023 100 100 025 Pre-fail Always - 100
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 25
193 Load_Cycle_Count 0x0012 100 100 000 Old_age Always - 25
194 Temperature_Celsius 0x0002 057 057 000 Old_age Always - 37 (Min/Max 20/39)
196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 0
197 Current_Pending_Sector 0x0022 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0008 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x000a 100 100 000 Old_age Always - 0
SMART Error Log Version: 1
No Errors Logged
1 Short offline Completed without error 00% 347 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Is something wrong here with the new drive or why I have the same situation each time zpool scrub is running?
Considering your SMART results are fine and you have checksum errors on /dev/ada4, I’d try re-seating / replacing the cables connecting the disk.
How is this currently connected to the system?
Thank you for your response.
All drives are internal SATA drives.
I shut down the system this morning. Then unplugged all SATA cables and plugged them in again. I’ll see if it comes back over time. So far there has been no zpool message from the system after startup
