Greetings to everyone, I want to tell you about an incident I have with the Truenas system, I raised my Pol and at the same time created my folders shared by SMB so far everything is fine, I tell you that I use the folder to feed but not to delete information, I left Explain, what I do is share the folder with a user group but I want the user to fill out the information or update it but not delete information. It is possible to make that user policy in TRUENAS, I just want to know if each user can see the folder. information fill the information in the folder or even update but do not delete data.
If a user can change files, they can effectively delete information within the file.
The strategy to avoid unwanted deletions is to snapshot the dataset/share frequently, so a file can be restored.
Otherwise, its use higher layer document control systems.
