Pterodactyl Panel upgrade fails
Hello all!
Im trying to update pterodactyl but always get this error:
  File "/usr/lib/python3/dist-packages/middlewared/job.py", line 515, in run
    await self.future
  File "/usr/lib/python3/dist-packages/middlewared/job.py", line 562, in __run_body
    rv = await self.middleware.run_in_thread(self.method, *args)
  File "/usr/lib/python3/dist-packages/middlewared/main.py", line 627, in run_in_thread
    return await self.run_in_executor(io_thread_pool_executor, method, *args, **kwargs)
  File "/usr/lib/python3/dist-packages/middlewared/main.py", line 624, in run_in_executor
  File "/usr/lib/python3.11/concurrent/futures/thread.py", line 58, in run
  File "/usr/lib/python3/dist-packages/middlewared/api/base/decorator.py", line 101, in wrapped
    result = func(*args)
  File "/usr/lib/python3/dist-packages/middlewared/plugins/apps/upgrade.py", line 133, in upgrade
    update_app_config(app_name, upgrade_version['version'], new_values)
  File "/usr/lib/python3/dist-packages/middlewared/plugins/apps/ix_apps/lifecycle.py", line 60, in update_app_config
    render_compose_templates(
  File "/usr/lib/python3/dist-packages/middlewared/plugins/apps/ix_apps/lifecycle.py", line 51, in render_compose_templates
    raise CallError(f'Failed to render compose templates: {cp.stderr}')
middlewared.service_exception.CallError: [EFAULT] Failed to render compose templates: Traceback (most recent call last):
  File "/usr/bin/apps_render_app", line 33, in <module>
    sys.exit(load_entry_point('apps-validation==0.1', 'console_scripts', 'apps_render_app')())
  File "/usr/lib/python3/dist-packages/catalog_templating/scripts/render_compose.py", line 48, in main
    render_templates_from_path(args.path, args.values)
  File "/usr/lib/python3/dist-packages/catalog_templating/scripts/render_compose.py", line 19, in render_templates_from_path
    rendered_data = render_templates(
  File "/usr/lib/python3/dist-packages/catalog_templating/render.py", line 31, in render_templates
    rendered_templates[i.name] = env.get_template(i.name).render(
  File "/usr/lib/python3/dist-packages/jinja2/environment.py", line 1301, in render
    self.environment.handle_exception()
  File "/usr/lib/python3/dist-packages/jinja2/environment.py", line 936, in handle_exception
    raise rewrite_traceback_stack(source=source)
  File "/mnt/.ix-apps/app_configs/pterodactyl-panel/versions/1.0.18/templates/docker-compose.yaml", line 10, in top-level template code
    {% set redis_container = tpl.deps.redis(values.consts.redis_container_name, "redis_image", redis_config, perm_container) %}
  File "/mnt/.ix-apps/app_configs/pterodactyl-panel/versions/1.0.18/templates/library/base_v2_1_49/deps.py", line 35, in redis
    return RedisContainer(self._render_instance, name, image, config, perms_instance)
  File "/mnt/.ix-apps/app_configs/pterodactyl-panel/versions/1.0.18/templates/library/base_v2_1_49/deps_redis.py", line 49, in __init__
    c.healthcheck.set_test("redis", {"password": config["password"]})
  File "/mnt/.ix-apps/app_configs/pterodactyl-panel/versions/1.0.18/templates/library/base_v2_1_49/healthcheck.py", line 50, in set_test
    self.set_custom_test(test_mapping(variant, config))
  File "/mnt/.ix-apps/app_configs/pterodactyl-panel/versions/1.0.18/templates/library/base_v2_1_49/healthcheck.py", line 43, in set_custom_test
    raise RenderError(f"Healthcheck with 'CMD' cannot contain shell variables '{test}'")
base_v2_1_49.error.RenderError: Healthcheck with 'CMD' cannot contain shell variables '['CMD', 'redis-cli', '-h', '127.0.0.1', '-p', '6379', '-a', '<redacted>', 'ping']'
What can i do to fix this? (Google wasnt really my friend in this case.)
It references midleware script so i thought i ask here 1st…
I doubt that you can fix it yourself because it looks like an error with the apps framework. I’d suggest filing a bug report on the apps section of the truenas github
Ok, thanks.
Ill leave a link to the issue here:
