RAIDZ1 pool degraded with big amount of write errors on a disk; but SMART long test passed
Hello.
I finished my expansion job on early December.
And then, my RAIDZ1 pool has been degraded 4 days ago with lots of write error.
One of my disk (Toshiba N300 7200/256M (HDWG21C, 12TB)) reported there are lots of write errors. The strange thing is: this disk was not the new one that I used for expansion.
zpool status
  pool: RAID5
 state: DEGRADED
status: One or more devices are faulted in response to persistent errors.
        Sufficient replicas exist for the pool to continue functioning in a
        degraded state.
action: Replace the faulted device, or use 'zpool clear' to mark the device
        repaired.
  scan: scrub repaired 0B in 1 days 04:17:12 with 0 errors on Sat Dec 14 22:52:46 2024
expand: expanded raidz1-0 copied 25.0T in 20 days 05:35:44, on Fri Dec 13 18:35:34 2024
        NAME                                      STATE     READ WRITE CKSUM
        RAID5                                     DEGRADED     0     0     0
          raidz1-0                                DEGRADED     0     0     0
            be64f67f-81d8-459c-a563-daffe3078fed  FAULTED      0    74     0  too many errors
            259a0b75-6c49-4561-8319-c920dbd33bbc  ONLINE       0     0     0
            59048391-9c54-4d6b-8c7d-54f4fe8b5bdf  ONLINE       0     0     0
            0da0b4a6-16fd-4a86-9141-821f846a3134  ONLINE       0     0     0
errors: No known data errors
However, my smartctl long test (performed on Dec 25) result reports that there is no disk error:
smartctl -x /dev/sda
ID# ATTRIBUTE_NAME          FLAGS    VALUE WORST THRESH FAIL RAW_VALUE
  1 Raw_Read_Error_Rate     PO-R--   100   100   050    -    0
  2 Throughput_Performance  P-S---   100   100   050    -    0
  3 Spin_Up_Time            POS--K   100   100   001    -    7035
  4 Start_Stop_Count        -O--CK   100   100   000    -    1481
  5 Reallocated_Sector_Ct   PO--CK   100   100   050    -    0
  7 Seek_Error_Rate         PO-R--   100   100   050    -    0
  8 Seek_Time_Performance   P-S---   100   100   050    -    0
  9 Power_On_Hours          -O--CK   039   039   000    -    24551
 10 Spin_Retry_Count        PO--CK   100   100   030    -    0
 12 Power_Cycle_Count       -O--CK   100   100   000    -    22
 23 Helium_Condition_Lower  PO---K   100   100   075    -    0
 24 Helium_Condition_Upper  PO---K   100   100   075    -    0
191 G-Sense_Error_Rate      -O--CK   100   100   000    -    0
192 Power-Off_Retract_Count -O--CK   100   100   000    -    8
193 Load_Cycle_Count        -O--CK   100   100   000    -    1534
194 Temperature_Celsius     -O---K   100   100   000    -    31 (Min/Max 19/62)
196 Reallocated_Event_Count -O--CK   100   100   000    -    0
197 Current_Pending_Sector  -O--CK   100   100   000    -    0
198 Offline_Uncorrectable   ----CK   100   100   000    -    0
199 UDMA_CRC_Error_Count    -O--CK   200   200   000    -    0
220 Disk_Shift              -O----   100   100   000    -    169738243
222 Loaded_Hours            -O--CK   041   041   000    -    23769
223 Load_Retry_Count        -O--CK   100   100   000    -    0
224 Load_Friction           -O---K   100   100   000    -    0
226 Load-in_Time            -OS--K   100   100   000    -    589
240 Head_Flying_Hours       P-----   100   100   001    -    0
                            ||||||_ K auto-keep
                            |||||__ C event count
                            ||||___ R error rate
                            |||____ S speed/performance
                            ||_____ O updated online
                            |______ P prefailure warning
General Purpose Log Directory Version 1
SMART           Log Directory Version 1 [multi-sector log support]
Address    Access  R/W   Size  Description
0x00       GPL,SL  R/O      1  Log Directory
0x01           SL  R/O      1  Summary SMART error log
0x02           SL  R/O     51  Comprehensive SMART error log
0x03       GPL     R/O      5  Ext. Comprehensive SMART error log
0x04       GPL,SL  R/O      8  Device Statistics log
0x06           SL  R/O      1  SMART self-test log
0x07       GPL     R/O      1  Extended self-test log
0x08       GPL     R/O      2  Power Conditions log
0x09           SL  R/W      1  Selective self-test log
0x0c       GPL     R/O    513  Pending Defects log
0x10       GPL     R/O      1  NCQ Command Error log
0x11       GPL     R/O      1  SATA Phy Event Counters log
0x24       GPL     R/O  53248  Current Device Internal Status Data log
0x25       GPL     R/O  53248  Saved Device Internal Status Data log
0x30       GPL,SL  R/O      9  IDENTIFY DEVICE data log
0x80-0x9f  GPL,SL  R/W     16  Host vendor specific log
0xe0       GPL,SL  R/W      1  SCT Command/Status
0xe1       GPL,SL  R/W      1  SCT Data Transfer
SMART Extended Comprehensive Error Log Version: 1 (5 sectors)
No Errors Logged
SMART Extended Self-test Log Version: 1 (1 sectors)
# 1  Extended offline    Completed without error       00%     24547         -
# 2  Short offline       Completed without error       00%     24529         -
What steps should I take to recover my pool WITHOUT replacing this disk with new disk (with the same size)? Or should I replace the disk anyway?
Intel(R) N100 CPU
16 GiB RAM (samsung, ddr5)
SK Hynix P31 gold 500G - boot
SK Hynix P31 gold 500G - ix-applications pool
Seagate Ironwolf NAS 12TB x 2, Toshiba N300 7200/256M (HDWG21C, 12TB), WD elements 14TB (exracted, WDBWLG0140HBK) - RAIDZ1
I read a post 10 years ago on FreeNAS forum: Freenas reports drive read/write errors, Long smart test shows no errors | TrueNAS Community
And it seems that turning off the system, re-inserting the disk, detach/reattach with /dev/sd(blah) worked.
Hmm… but anyway SMART test does not tells that this disk is 100% okay, so I am preparing a spare disk, but I know that resilvering with that disk will take 20 days or more, so I want to recover this situation.
Your error is with ZFS, not a drive failure based on the indications provided.
Run a SCRUB on the pool zpool scrub RAID5, verify it passes, if it does then run zpool clear RAID5, then run zpool status RAID5 to ensure the errors are cleared. If the problem occurs again, make another post.
Thank you. After that, I will resilver the pool if needed.
Your spec shows 3x HDDs (2x Ironwolf, 1x N300), zpool status shows 4x HDDs. What is the other disk?
The scrub is all you need, if there are no errors then all is good, you just need to clear the error flags, then you verify the error flags were cleared.
If the scrub identifies corrupt files, you will need to delete those files and restore those with a backup copy, then repeat the steps above to verify all is good.
If the problem returns, do the following:
zpool status RAID5
lsblk -o +PARTUUID,NAME | grep "part"
lsblk -o +SERIAL,NAME | grep "disk"
or you could grab the entire list and visually sort through it:
lsblk -o PARTUUID,NAME,SERIAL
Make sure the drive is the same one you suspect, verify using the serial number, not the drive ID/name (sda, sdb…) as the ID can change during a reboot.
If you have a question, please ask. One on wants anyone to loose data if it can be prevented. Remember, while a failing drive can cause data corruption, it does not mean a drive failure was the cause. Often a scrub failure (read/write/cksum) are not due to a physical drive failure, so never jump to conclusions without verifying. And you did the right thing by running a SMART Long test.
I highly recommend that you setup daily SMART Short tests and weekly SMART Long tests. If a weekly long test feels excessive to you, at least monthly however I prefer weekly. With a 12TB drive, I would schedule one Long test a day, example, Monday = sda, Tuesday = sdb, etc.
Best of luck to you.
Oh, sorry. I missed to update my HDD spec. My other HDD is WD Elements 14TB(WDBWLG0140HBK), so this is a pool with 3 12TB hdd and 1 14TB pool.
After I restarted my NAS before doing systematical changes like you suggested (in other words, scrub), it automatically started resilvering on the disk(toshiba 12tb; /dev/sda) that had write errors.
It will take more than 20 days according to zpool status, but still I think stopping that process manually would be dangerous.
Is it okay to let it finish resilvering automatically and perform scrub after that?
Absolutely it is fine and in my book, preferred. With that said, I would highly recommend that you backup any really important files you can. If you are like me, I have under 5TB of data I must retain and that can and does fit on a 5TB removable archive drive. Doing this will bring you a little piece of mind.
That’s not to say ZFS has a bug.
ZFS has detected an error, and quite possibly SMART has not.
We don’t know because you didn’t include all the smart results, or all the smart result and a serial list.
Thank you. I didn’t import other half of the SMART result since I didn’t find anomalies on that. Here is the other half of the result on /dev/sda:
SCT Status Version:                  3
SCT Version (vendor specific):       1 (0x0001)
Device State:                        Active (0)
Current Temperature:                    31 Celsius
Power Cycle Min/Max Temperature:     21/37 Celsius
Lifetime    Min/Max Temperature:     19/62 Celsius # this 62 celsius is not the value I have experienced, maybe from the former user's experience. In my device, around 40 celsius was the highest.
Specified Max Operating Temperature:    55 Celsius
Under/Over Temperature Limit Count:   0/0
SCT Temperature History Version:     2
Temperature Sampling Period:         1 minute
Temperature Logging Interval:        1 minute
Min/Max recommended Temperature:      5/55 Celsius
Min/Max Temperature Limit:           -40/70 Celsius
Temperature History Size (Index):    478 (54)
Index    Estimated Time   Temperature Celsius
  55    2024-12-26 13:51    35  ****************
 ...    ..(175 skipped).    ..  ****************
 231    2024-12-26 16:47    35  ****************
 232    2024-12-26 16:48    36  *****************
 ...    ..(  3 skipped).    ..  *****************
 236    2024-12-26 16:52    36  *****************
 237    2024-12-26 16:53    35  ****************
 238    2024-12-26 16:54    36  *****************
 239    2024-12-26 16:55    35  ****************
 240    2024-12-26 16:56    36  *****************
 ...    ..( 20 skipped).    ..  *****************
 261    2024-12-26 17:17    36  *****************
 262    2024-12-26 17:18    35  ****************
 263    2024-12-26 17:19    35  ****************
 264    2024-12-26 17:20    36  *****************
 265    2024-12-26 17:21    36  *****************
 266    2024-12-26 17:22    35  ****************
 ...    ..(  2 skipped).    ..  ****************
 269    2024-12-26 17:25    35  ****************
 270    2024-12-26 17:26    36  *****************
 271    2024-12-26 17:27    35  ****************
 ...    ..( 28 skipped).    ..  ****************
 300    2024-12-26 17:56    35  ****************
 301    2024-12-26 17:57    34  ***************
 ...    ..(  5 skipped).    ..  ***************
 307    2024-12-26 18:03    34  ***************
 308    2024-12-26 18:04    33  **************
 ...    ..(  9 skipped).    ..  **************
 318    2024-12-26 18:14    33  **************
 319    2024-12-26 18:15    32  *************
 320    2024-12-26 18:16    33  **************
 323    2024-12-26 18:19    33  **************
 324    2024-12-26 18:20    32  *************
 353    2024-12-26 18:49    32  *************
 354    2024-12-26 18:50    31  ************
 ...    ..(143 skipped).    ..  ************
  20    2024-12-26 21:14    31  ************
  21    2024-12-26 21:15    30  ***********
  22    2024-12-26 21:16    31  ************
 ...    ..( 31 skipped).    ..  ************
  54    2024-12-26 21:48    31  ************
SCT Error Recovery Control:
           Read: Disabled
          Write: Disabled
Device Statistics (GP Log 0x04)
Page  Offset Size        Value Flags Description
0x01  =====  =               =  ===  == General Statistics (rev 3) ==
0x01  0x008  4              22  ---  Lifetime Power-On Resets
0x01  0x010  4           24551  ---  Power-on Hours
0x01  0x018  6     74427863782  ---  Logical Sectors Written
0x01  0x020  6      1026033388  ---  Number of Write Commands
0x01  0x028  6    203765309018  ---  Logical Sectors Read
0x01  0x030  6      1049888193  ---  Number of Read Commands
0x01  0x038  6     88383600000  ---  Date and Time TimeStamp
0x02  =====  =               =  ===  == Free-Fall Statistics (rev 1) ==
0x02  0x010  4               0  ---  Overlimit Shock Events
0x03  =====  =               =  ===  == Rotating Media Statistics (rev 1) ==
0x03  0x008  4            1131  ---  Spindle Motor Power-on Hours
0x03  0x010  4            1101  ---  Head Flying Hours
0x03  0x018  4            1534  ---  Head Load Events
0x03  0x020  4               0  ---  Number of Reallocated Logical Sectors
0x03  0x028  4               9  ---  Read Recovery Attempts
0x03  0x030  4               0  ---  Number of Mechanical Start Failures
0x03  0x038  4               0  ---  Number of Realloc. Candidate Logical Sectors
0x03  0x040  4               8  ---  Number of High Priority Unload Events
0x04  =====  =               =  ===  == General Errors Statistics (rev 1) ==
0x04  0x008  4               0  ---  Number of Reported Uncorrectable Errors
0x04  0x010  4               2  ---  Resets Between Cmd Acceptance and Completion
0x05  =====  =               =  ===  == Temperature Statistics (rev 1) ==
0x05  0x008  1              31  ---  Current Temperature
0x05  0x010  1              34  N--  Average Short Term Temperature
0x05  0x018  1              32  N--  Average Long Term Temperature
0x05  0x020  1              62  ---  Highest Temperature
0x05  0x028  1              19  ---  Lowest Temperature
0x05  0x030  1              61  N--  Highest Average Short Term Temperature  # this 62 celsius is not the value I have experienced, maybe from the former user's experience. In my device, around 40 celsius was the highest.
0x05  0x038  1              27  N--  Lowest Average Short Term Temperature
0x05  0x040  1              56  N--  Highest Average Long Term Temperature
0x05  0x048  1              31  N--  Lowest Average Long Term Temperature
0x05  0x050  4          194800  ---  Time in Over-Temperature
0x05  0x058  1              55  ---  Specified Maximum Operating Temperature
0x05  0x060  4               0  ---  Time in Under-Temperature
0x05  0x068  1               5  ---  Specified Minimum Operating Temperature
0x06  =====  =               =  ===  == Transport Statistics (rev 1) ==
0x06  0x008  4             195  ---  Number of Hardware Resets
0x06  0x010  4              69  ---  Number of ASR Events
0x06  0x018  4               0  ---  Number of Interface CRC Errors
0x07  =====  =               =  ===  == Solid State Device Statistics (rev 1) ==
                                |||_ C monitored condition met
                                ||__ D supports DSN
                                |___ N normalized value
Pending Defects log (GP Log 0x0c)
No Defects Logged
SATA Phy Event Counters (GP Log 0x11)
ID      Size     Value  Description
0x0001  4            0  Command failed due to ICRC error
0x0002  4            0  R_ERR response for data FIS
0x0003  4            0  R_ERR response for device-to-host data FIS
0x0004  4            0  R_ERR response for host-to-device data FIS
0x0005  4            0  R_ERR response for non-data FIS
0x0006  4            0  R_ERR response for device-to-host non-data FIS
0x0007  4            0  R_ERR response for host-to-device non-data FIS
0x0008  4            0  Device-to-host non-data FIS retries
0x0009  4            6  Transition from drive PhyRdy to drive PhyNRdy
0x000a  4            6  Device-to-host register FISes sent due to a COMRESET
0x000b  4            0  CRC errors within host-to-device FIS
0x000d  4            0  Non-CRC errors within host-to-device FIS
0x000f  4            0  R_ERR response for host-to-device data FIS, CRC
0x0010  4            0  R_ERR response for host-to-device data FIS, non-CRC
0x0012  4            0  R_ERR response for host-to-device non-data FIS, CRC
0x0013  4            0  R_ERR response for host-to-device non-data FIS, non-CRC
For the serial list, is lsblk -bo NAME,MODEL,ROTA,PTTYPE,TYPE,START,SIZE,PARTTYPENAME,PARTUUID sufficient?
sda         WDC WD140EDGZ-11B2DA2    1 gpt    disk          14000519643136
└─sda1                               1 gpt    part     2048 14000518577664 Solaris /usr & Apple ZFS 0da0b4a6-16fd-4a86-9141-821f846a3134
sdb         TOSHIBA HDWG21C          1 gpt    disk          12000138625024
└─sdb1                               1 gpt    part     4096 12000136510976 Solaris /usr & Apple ZFS be64f67f-81d8-459c-a563-daffe3078fed
sdc         ST12000VN0008-2PH103     1 gpt    disk          12000138625024
└─sdc1                               1 gpt    part     4096 12000136510976 Solaris /usr & Apple ZFS 259a0b75-6c49-4561-8319-c920dbd33bbc
sdd         ST12000VN0008-2PH103     1 gpt    disk          12000138625024
└─sdd1                               1 gpt    part     4096 12000136510976 Solaris /usr & Apple ZFS 59048391-9c54-4d6b-8c7d-54f4fe8b5bdf
nvme0n1     SHGP31-500GM             0 gpt    disk            500107862016
├─nvme0n1p1                          0 gpt    part     4096        1048576 BIOS boot                f0c5003c-678f-4c25-8c38-5dc6bef11ec8
├─nvme0n1p2                          0 gpt    part     6144      536870912 EFI System               a72994ef-da12-44a0-beac-0ee566c111d9
├─nvme0n1p3                          0 gpt    part 34609152   482387959296 Solaris /usr & Apple ZFS e58f1410-1215-407a-988e-d050f8e2a963
└─nvme0n1p4                          0 gpt    part  1054720    17179869184 Linux swap               072560bc-e4c4-4c2d-892d-7a92bdbe4e78
nvme1n1     SHGP31-500GM             0 gpt    disk            500107862016
└─nvme1n1p1                          0 gpt    part     4096   500105740800 Solaris /usr & Apple ZFS 160079d5-e1f6-419f-bf09-a638629bf052
NOTE: after rebooting (re-attaching disks and rebooted), sda and sdb has been swapped (you could notice that now /dev/sdb is TOSHIBA disk). I posted the result of /dev/sdb’s smartctl correctly though.
This is not quite correct. There are a whole bunch of errors that are entirely ZFS errors and not at all SMART errors such as checksum errors. There are also a whole bunch of SMART errors that are often not ZFS errors (like reallocated sectors).
There are probably also some which are both types at the same time.
