Hi all,
Busy deleting/removing TrueCharts,
I’ve already removed the repository and all apps deployed, except “ClusterIssuer” and “metallb-config”
When doing a delete on them they both show the following in a error block
errorFAILED
[EFAULT] Unable to uninstall 'clusterissuer' chart release: b'Error: failed to delete release: clusterissuer\n'
add_circle_outlineMore info...
and if I click more information then I got he following
File "/usr/lib/python3/dist-packages/middlewared/job.py", line 469, in run
await self.future
File "/usr/lib/python3/dist-packages/middlewared/job.py", line 511, in __run_body
rv = await self.method(*args)
File "/usr/lib/python3/dist-packages/middlewared/service/crud_service.py", line 210, in nf
rv = await func(*args, **kwargs)
File "/usr/lib/python3/dist-packages/middlewared/schema/processor.py", line 47, in nf
res = await f(*args, **kwargs)
File "/usr/lib/python3/dist-packages/middlewared/schema/processor.py", line 187, in nf
File "/usr/lib/python3/dist-packages/middlewared/plugins/chart_releases_linux/chart_release.py", line 601, in do_delete
raise CallError(f'Unable to uninstall {release_name!r} chart release: {cp.stderr}')
middlewared.service_exception.CallError: [EFAULT] Unable to uninstall 'clusterissuer' chart release: b'Error: failed to delete release: clusterissuer\n'
