Under CORE, I had a script that I used occasionally to clean up old “auto” Snapshots that were not a part of my “daily” set - ones created by TrueNAS itself, that I wanted to remove to free up space once I was sure I no longer needed them. That script was:
for s in `zfs list -r -t snap -H -o name /mnt/data | grep @auto` ; do
zfs destroy -p $s ;
done
When I try to run this under SCALE (24 / Dragonfish), it doesn’t recognize the command “zfs” - is there an alternative I can use to automatically remove snapshots matching a specific text string?
Thank you!
