Renamed zpool and now instances storage pool is not matching
Sorry this is my first post. I renamed my zpool from NAS to tank and now when i try to access instances i get the following error.
[EFAULT] The configured incus storage pool for the ZFS pool tank is NAS, which should match the ZFS pool name. This mismatch may indicate that the TrueNAS ix-virt dataset was not initially created on this ZFS pool.
I’ve tried remove the .ix-virt directory but the issue is still persisting. Did i just completely bork my config?
I’ve tried the below command from this post but i still get the same error as above.
midclt call virt.global.update '{"pool": null, "storage_pools": []}' -j
I don’t currently have any virtual machines so i’m happy to reset the config if thats an option?
Thanks for the help
