I’ve looked through the community forum and user manual and I can find some topics which are related, but nothing exactly like my situation. If someone can direct me to a relevant post, I would be grateful.
I have “FreeBSD 13.1-RELEASE-p7 n245418-79e75956dbb TRUENAS” with 5 disks:
- 128G SSD - the TRUENAS system drive
- 2 3 TB HDDs, mirrored, with 1 pool “netstore”
- 2 1TB HDDs, mirrored, with 1 pool “netstore2”
I would like to replace the 4 HDDs with 2 4TB SSDs and put both pools onto these. I have 1 spare SATA socket.
So, my plan is to put 1 new 4TB SSD in the spare SATA socket and add this to the “netstore” pool. Then remove one of the 3TB HDDs from that pool, put the other new 4TB SSD in the now vacant slot, add it to the “netstore” pool and then remove the 2nd 3TB HDD.
Now, I think all that’s left is to migrate the “netstore2” pool onto the new SSD pair. I don’t know how to do that (I suspect a sequence of export, shut down, import steps, but I’m not clear). I also don’t know if I need to do anything with the new SSDs to prepare for this before I do anything else, e.g., partition the disks.
Any help much appreciated. Let me know if any further information would be useful.
