Reporting Disk Temperature 24.10 Electric Eel
After upgrading from Dragon Fish to Electric Eel
in disk reporting, even if you ask for both disk io e disk temperature
there is no way to have the disk temperature.
Disk reporting doesn’t show anymore the disk temperature
You can go from storage to disk report
or directly from reporting nothing changes
You’ll need to be more clear about your hardware and what kind of discs have lost temperature reporting, as this is not a wide-spread issue we’ve seen.
You also should try clearing your browser cache if you have not already.
Every disks hdd and ssd
hardware is a pc with truenas
I have this problem too. I have always had temperature reporting for my disks and they have stopped being available since updating to Electric Eel. I am running TrueNAS Scale on a HP Z420 tower, original motherboard, HBA card, seven sata HDDs plus one sata SSD with the system install, disks are attached to a mix of the HBA and onboard sata ports on the mobo. CPU is Intel(R) Xeon(R) CPU E5-1607 v2 @ 3.00GHz, 48GB ECC RAM.
Is it just the disk temperature that doesn’t work?
Can you post a screenshot?
Just the disk temp as far as I can see. I used to have Disk Temperature available in the dropdown in the screenshot. The first boot after upgrading to Electric Eel, the option was still there but didn’t do anything when you selected it. I rebooted last night to replace a disk and on new boot, the option is gone.
I’m not being allowed to insert a picture or link (maybe because my account is new?) but you can cp below:
www. dropbox. com /scl/fi/g60yu9mcqkmdc3c8m4ogf/truenas.png?rlkey=husn47xn9sgok2yo4tf1p24nv&st=himul7av&dl=0
Slight addendum - this is interesting. Just now when I looked again, now see the temperature option is back but shows no data, see here:
www. dropbox. com /scl/fi/hwr3lpkp87vk6szxydt64/truenas2.png?rlkey=omrar3qmyo39ocl49wa1ws7pc&st=fke4zbw8&dl=0
I can’t tell you if I got to it the first time a different way, but the second time I went to side menu - storage - disk health panel - view reports.
Sorry, a further addendum: On going in again just now, the Disk Temperature area is populated, but not with temperature data.
www .dropbox. com /scl/fi/nigc5qw5zd9eu1cyhy5ll/truenas3.png?rlkey=n3x11fhw4qza0hmhk3dmaujxk&st=ip14ey1o&dl=0
Adding pictures. they should match OP posters order. Otherwise gave number prefix to file names
If you are hitting the new user post limit. Try to message a moderator or a user that replies to this thread. You should get bumped up just by interacting with the forum
https://forums.truenas.com/about
