Hello all
I had to rebuild my secondary truenas scale server (bare metal) because of a full boot drive and because i had issues with my pool.
I screwed up this simple process and I decided to re builed the whole server.
Prior to this all was working fine
the server is up and running and the datasets mirror the datasets on my main server.
Both server datasets ACLs and share are identical.
I see that i can no longer use module when i create an rsync task and i will need to use the ssh connection from the key chain. . . so be it
I build the rsync task and i get
[EFAULT] rsync command returned 255 - UNKNOWN
I have the user of the task root so this should circumvent all securities correct.
still no joy
I searched youtube and this forum and i do not see a path to resolve my issue
Can someone please directme to a solution
