Is it possible to run docker compose files from the command line please?
I’m using dockge now but it created some problems that were solved buy deleting and recreating a stack with exactly the same yaml. It has shaken my trust.
Thanks.
Thanks.
Why not try it - that would answer your question
since it’s plain docker under the hood it should work with no problems - only thing that could be is that the app won’t show up in the apps tab in the gui
In the very short period I’ve used TrueNAS, I’ve learned there is a huge difference between what you can do, what you are allowed to do and what is best practice. I have 30 years of IT experience behind me and I’ve never been so uncertain to configure a system as with TrueNAS. It all started with restoring the data of my previous NAS and the conflicting advice on YT doesn’t help. ![]()
