Hello all
I’m running truenas scale as a vm on a proxmox server (server A).
this server is running 24/7
I have a second server running truenas scale on bare metal *server b). this server runs on saturday only while i backup server A to serve B.
Last week I had to destroy and re-build server B because i blundered substituting a broken HD and i destroyed the pool.
I rebuilt all the share on server B as the were before and i proceeded to rsync all my datasets all was working fine.
the backup of all the datasets was proceeding correctly and on schedule.
Because i was in a hurry, I decided to copy from server A a dataset (the largest one) and paste it manually to server B
again all went well
However I still needed to test the rsync task from that dataset.
Therefore I started the rsync task from server A to server B
This task have been running for over 16 hours
On clicking on the jobs icon i can see that the task is running however the progress bar does not move and remain at 0.00?
How do i see the progress of this task and confirm that it’s not spinning its wheels and that it is actually doing something?
the dataset is about 3.6 TB
In my honest opinion since B is replica of A this task should not take this long
