I love the new jail functionality. So following the excellent tutorial by capt stux (see this youtube video on jailmaker on truenas scale), i created a stack for tailscale.
I tore my hair out for 30 minutes because I couldn’t access any of the ports on docker remotely via tailscale.
The simplest solution is to use Host Network. This is a checkbox in the app version of tailscale. With jlmkr, I’m using Dockge as recommended in the video. Here is the compose.yaml file I use with tailscale which has network_mode: host which enabled me to access all the ports from the tailscale docker host:
version: "3.8"
services:
tailscale:
restart: unless-stopped
image: tailscale/tailscale:latest
network_mode: host
environment:
- TS_AUTHKEY=tskey-auth-kbW2JNQCXy11CNTRL-j64eZFwjwwea882aNDFL_sBEaicKDFYS
- TS_ACCEPT_DNS=true # accept DNS
- TS_HOSTNAME=docker
- TS_STATE_DIR=/var/lib/tailscale # location in container for persistent data
volumes:
- /mnt/main/docker/data/tailscale:/var/lib/tailscale
networks: {}
(that’s not the real API key, don’t worry)
So now I can invite any of my trusted friends to my tailscale host to enable them to access my jailmaker apps on any port.
