Samba Winbind Idmap AD range (Core to Scale)
Hello, I am in the process of migrating from Core to Scale. I installed my new server and had issues about idmap ad range when joining my Samba AD domain.
In the past I probably made a mistake by assigning the Domain Administrators and Domain Users groups a gidNumber of 512 and 513 (to be consistent with RID) in our Samba AD. Subsequently I had to tweak the configuration on our TrueNas Core by adding in the advanced options “idmap config MYDOMAIN: range = 500-32768” because idmap range minimum value is 1000. It turns out that the Truenas Scale interface does not allow you to add this parameter.
As I would like to do things properly, can I proceed as follows:
  1. modify in my Samba AD the gidNumber from 512/513 to 1512/1513 with lbdedit;
  2. on my TrueNas Core edit all directories and files with chgrp: find . -gid 512 -print0 | xargs -0r chgrp 1512
    Will this be enough without having to modify the NFSv4 ACLs?
It depends on whether you used that gid in any ACLs. Perhaps you won’t need to change anything.
Thanks for your reply. ACL mode is set to Restricted and I think that it is only used on files and directories created by users on Windows which assign group to Domain Users.
On the source Core server I have:
root@xx:/mnt/vol1/xx/data # getent group ADM\\domain\ users
ADM\domain users:x:513
root@x:/mnt/vol1/xx/data # ls -ld ./SOUTENANCES/.DS_Store
-rwxrwxrwx+ 1 ADM\yyyyyy  ADM\domain users  18436 Apr 22  2024 ./SOUTENANCES/.DS_Store
root@carioca:/mnt/vol1/carioca/data # ls -ldn ./SOUTENANCES/.DS_Store
-rwxrwxrwx+ 1 6069  513  18436 Apr 22  2024 ./SOUTENANCES/.DS_Store
root@x:/mnt/vol1/xx/data # getfacl ./SOUTENANCES/.DS_Store
 file: ./SOUTENANCES/.DS_Store
 owner: ADM\yyyyyy
 group: ADM\domain users
     user:nasadmin:rwxpDdaARWcCo-:-------:allow
            owner@:rwxpDdaARWcCo-:-------:allow
    group:nasadmin:rwxpDdaARWcCo-:-------:allow
            group@:rwxpDdaARWcCo-:-------:allow
         everyone@:rwxpDdaARWcCo-:-------:allow
On the new Scale server (with datasets replicated):
root@zzzz[/mnt/vol1/xx/data]# getent group ADM\\domain\ users
ADM\domain users:x:1513:
root@rumba[/mnt/vol1/xx/data]# ls -ld ./SOUTENANCES/.DS_Store
-rwxrwxrwx 1 ADM\yyyy 513 18436 Apr 22  2024 ./SOUTENANCES/.DS_Store
root@rumba[/mnt/vol1/carioca/data]# nfs4xdr_getfacl ./SOUTENANCES/.DS_Store
 File: ./SOUTENANCES/.DS_Store
 owner: 6069
 group: 513
 mode: 0o100777
 trivial_acl: false
 ACL flags: none
      user:netdata:rwxpDdaARWcCo-:-------:allow
      group:docker:rwxpDdaARWcCo-:-------:allow
I think I will have to change my old local nasadmin user and group (id 999) to truenas_admin local user and change the root acl of the dataset.
