Morning all.
So with the release of electric Eel, I decided it was finally time to expand the capacity of my offsite backup server, which has been sat at 90% capacity for a while now (yes, i know, i know). I was having some issues with it, as seemingly new drives kept faulting, and at one point, had 3 drives faulted (16x8Tb drives in Raidz3). After visiting my friend who kindly hosts the server for me, and taking a load of spares, I identified the issue as either a bad backplane on one of the rows of my 24x chassis, or a bad HBA, as all but one drive faulted, but then this cleared on another reboot.Thankfully I had brought 2 spare drives with me, so i dropped dropped both in, and started the expansion. After only a few minutes of expansion, a drive dropped, I took the bad drive out and tested it in my USB Toaster, and it is indeed bad (fails SMART, only had 500 hours on it). I invoked the 2nd spare as a replacement, and thats been rebuilding now for the past few days (I’m now back home). The resilver completed, and the expansion resumed, and has as of now reached 26.23% (i’ll come back to that in a second)
Heres where it goes strange. Since my hardware issues started, the server has been painfully slow to load drive data in the GUI. When i go to storage, the page template loads, but its a good 45 to 60 seconds before it lists the drives. Since adding the replacement into the pool, I have two entries in drive list for /dev/sdf, both with the same serial number, one faulted, one not. I don’t think the new drive shows in the pool in the GUI yet, but I have 17 drives (when counting the 2 entries.). Its been like this since that first drive failure, and has been rebuilding since. I’d hoped that once the rebuilt was completed, it would sort itself out, but this morning, its stopped again at 26.23%, stating “expand: expansion of raidz3-0 in progress since Tue Nov 26 23:17:57 2024
27.2T / 104T copied at 44.5M/s, 26.23% done, paused for resilver or clear”.
Above it states “status: One or more devices could not be used because the label is missing or
invalid. Sufficient replicas exist for the pool to continue
functioning in a degraded state.”
At this point i decided it was time to consult the experts (thats you lot
Here are some outputs, hopefully they make more sense to you…
root@Plutonium[~]# zpool status Backup_Array
pool: Backup_Array
state: DEGRADED
action: Replace the device using 'zpool replace'.
see: https://openzfs.github.io/openzfs-docs/msg/ZFS-8000-4J
scan: resilvered 7.93M in 00:00:06 with 0 errors on Wed Dec 4 08:58:48 2024
NAME STATE READ WRITE CKSUM
Backup_Array DEGRADED 0 0 0
raidz3-0 DEGRADED 0 0 0
sdn2 ONLINE 0 0 0
sdo2 ONLINE 0 0 0
sdm2 ONLINE 0 0 0
sdh2 ONLINE 0 0 0
6959709699627927323 FAULTED 0 0 0 was /dev/sdf2
sdl2 ONLINE 0 0 0
sdi2 ONLINE 0 0 0
sdj2 ONLINE 0 0 0
sdg2 ONLINE 0 0 0
sdf2 ONLINE 0 0 0
sdd2 ONLINE 0 0 0
sdc2 ONLINE 0 0 0
sds2 ONLINE 0 0 0
sdq2 ONLINE 0 0 0
sdt2 ONLINE 0 0 0
sdv2 ONLINE 0 0 0
44baec85-b81c-400e-aa3e-e9a95801a3c8 ONLINE 0 0 0
dedup
mirror-3 ONLINE 0 0 0
nvme-INTEL_SSDPE21D280GA_PHM2749000E1280AGN-part2 ONLINE 0 0 0
nvme-INTEL_SSDPE21D280GA_PHM27490007S280AGN-part2 ONLINE 0 0 0
special
mirror-1 ONLINE 0 0 0
sde1 ONLINE 0 0 0
sdb1 ONLINE 0 0 0
sda1 ONLINE 0 0 0
logs
mirror-2 ONLINE 0 0 0
nvme-INTEL_SSDPE21D280GA_PHM2749000E1280AGN-part1 ONLINE 0 0 0
nvme-INTEL_SSDPE21D280GA_PHM27490007S280AGN-part1 ONLINE 0 0 0
errors: No known data errors
root@Plutonium[~]#
(not letting me upload the image)
root@Plutonium[~]# smartctl -a /dev/sdf
smartctl 7.4 2023-08-01 r5530 [x86_64-linux-6.6.44-production+truenas] (local build)
Copyright (C) 2002-23, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family: Seagate IronWolf
Device Model: ST8000VN004-2M2101
Serial Number: WSD8VQKE
LU WWN Device Id: 5 000c50 0e53fb265
Firmware Version: SC60
User Capacity: 8,001,563,222,016 bytes [8.00 TB]
Rotation Rate: 7200 rpm
Form Factor: 3.5 inches
Device is: In smartctl database 7.3/5528
ATA Version is: ACS-4 (minor revision not indicated)
SATA Version is: SATA 3.3, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Wed Dec 4 09:56:16 2024 GMT
SMART support is: Enabled
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
been run.
data collection: ( 567) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 707) minutes.
Conveyance self-test routine
SCT capabilities: (0x50bd) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x000f 078 064 044 Pre-fail Always - 56816472
3 Spin_Up_Time 0x0003 081 080 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 121
5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 0
7 Seek_Error_Rate 0x000f 084 060 045 Pre-fail Always - 245827568
9 Power_On_Hours 0x0032 096 096 000 Old_age Always - 3582
10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 121
18 Head_Health 0x000b 100 100 050 Pre-fail Always - 0
187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0
188 Command_Timeout 0x0032 100 100 000 Old_age Always - 0
190 Airflow_Temperature_Cel 0x0022 071 050 040 Old_age Always - 29 (Min/Max 29/39)
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 55
193 Load_Cycle_Count 0x0032 098 098 000 Old_age Always - 5782
194 Temperature_Celsius 0x0022 029 050 000 Old_age Always - 29 (0 4 0 0 0)
195 Hardware_ECC_Recovered 0x001a 078 064 000 Old_age Always - 56816472
197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 1778h+55m+53.315s
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 81788753984
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 155379209968
SMART Error Log Version: 1
No Errors Logged
# 1 Extended offline Interrupted (host reset) 10% 3456 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
The above only provides legacy SMART information - try 'smartctl -x' for more
root@Plutonium[~]#
Home Brew Server
Intel(R) Xeon(R) CPU E5-2630 v4
64Gb Ram
3x [LSI 9211-8i IT Mode SAS HBA’s
750w Corsair PSU
2x Intel Optane 900’s (dedup and SLOGs)
3x Samsung PM1635a Mirrored MetaData drives
2x Sandisk 240Gb boot SSDs
