SCALE: Better support for SMB without Active Directory
Problem/Justification
It would be extremely useful if we could enable SMB shares using plain Kerberos auth and LDAP rather than having to join to an Active Directory domain. Samba supports this, but there is no exposure of this functionality in the TrueNAS SCALE UI. TrueNAS CORE appears to have had a field to add auxiliary parameters to the smb.conf file, but SCALE does not.
Impact
Benefits: more flexibility for diverse environments where Windows is a secondary service, not the primary service. Users will be able to create SMB shares without having to rely on either Active Directory or insecure/deprecated NTLM passwords stored locally.
Disadvantages: I can’t really think of any, and it shouldn’t be that hard to implement. At bare minimum, SCALE should allow custom additions to the Samba config in the same way that CORE does.
User Story
We operate a mixed environment, which is primarily Unix/Linux using local/LDAP auth, with some Windows systems which are joined to Active Directory. Our UID/GID number space is local to us, but Active Directory serves the whole institution and has no support for POSIX information. Since our Kerberos realm trusts the AD Realm, it should still work with plain Kerberos if the UI would allow the configuration.
If we were to join the TrueNAS systems to Active Directory instead, it would introduce a lot of complication for us and would limit us to using NFS version 4 for our Unix systems since ID mapping would then be required due to our local UID/GID number space.
original issue was: NAS-132139
We added support for SMB + FreeIPA in 24.10. That said, you’re often limited by what your clients support WRT kerberos auth.
We are not using FreeIPA, but rather we have our own OpenLDAP directory and the institution provides an MIT Keberos realm. I just tried this out on 24.10 and, while it still produces the dialog box saying that AD or local Samba auth is required, it allows the share to be created. Now I am just having issues authenticating with Kerberos even though the keytab on the truenas has a cifs SPN
You can look at what we do for IPA for some inspiration for samba configuration changes, but I don’t really think this configuration is easily supportable. middleware/src/middlewared/middlewared/plugins/smb_/util_smbconf.py at 0551c438bbf27e08f32ec3e7126afb8f9fbea62f · truenas/middleware · GitHub
You can also look at the IPA source itself:
Looking at that code, it really shouldn’t be hard to support this because basically everything you are doing to support it with IPA would be almost the same as for plain Kerberos. The main things would be using a different path to the keytab and pulling the realm and workgroup from the SMB config rather than the IPA config. All of this information should already be available in TrueNAS since we can configure keytabs and realms on the directory services page and the workgroup is configured on the SMB services config.
Samba will already map SMB users using NSS (it requires them to be resolvable via NSS), so it really just needs to be told to use Kerberos and where to find the keytab.
Have you actually proved this out on a non-TrueNAS samba server? There are some subtleties here when we go about generating the keytab for the cifs/spn to ensure that Samba’s secrets.tdb is also populated with correct domain info.
The required info for samba databases is returned as part of generating the cifs spn / keytab by the IPA client.
Yes, I just confirmed that it works with plain MIT kerberos. This was the config that worked for me once I got my principals configured correctly:
[global]
        workgroup = WORKGROUP
        security = user
        realm = MYREALM
        kerberos method = system keytab
        client use kerberos = required
        lanman auth = no
        ntlm auth = no
        server role = standalone
        idmap config * : range = 1000 - 999999
        passdb backend = tdbsam
With that configuration, I was then able to successfully connect using the smbclient command on another linux machine after doing kinit.
Okay. I’ll look into tweaking the smb config if we’re not a member of an IPA domain and have a keytab containing a cifs spn. Probably NET 25.04.
Hi Andrew, can you confirm whether or not this will be in 25.04? I did a quick search in Jira but did not see a related issue.
Thanks!
@awalkerix is this going to make it into 25.04?
Any news on this?
