I’m a linux Noob so seeking some assistance please.
I passed through my GPU to a VM using the Menu for isolation. Something went wrong and now the NIC is also isolated from the host.
The VM GPU passthrough works but the Host cannot use the NIC anymore.
Output from lspci -v
I need the NIC to not be VFIO if that makes sense
//How do I create a code block?//
01:00.0 Ethernet controller: Aquantia Corp. AQC107 NBase-T/IEEE 802.3bz Ethernet Controller [AQtion] (rev 02)
Subsystem: Aquantia Corp. AQC107 NBase-T/IEEE 802.3bz Ethernet Controller [AQtion]
Flags: fast devsel, IRQ 11, IOMMU group 2
Memory at f6c00000 (64-bit, non-prefetchable) [disabled] [size=64K]
Memory at f6c10000 (64-bit, non-prefetchable) [disabled] [size=4K]
Memory at f6800000 (64-bit, non-prefetchable) [disabled] [size=4M]
Capabilities: [40] Express Endpoint, MSI 00
Capabilities: [80] Power Management version 3
Capabilities: [90] MSI-X: Enable- Count=32 Masked-
Capabilities: [a0] MSI: Enable- Count=1/32 Maskable- 64bit+
Capabilities: [c0] Vital Product Data
Capabilities: [100] Advanced Error Reporting
Capabilities: [150] Vendor Specific Information: ID=0001 Rev=1 Len=024 <?>
Capabilities: [180] Secondary PCI Express
Kernel driver in use: vfio-pci
Kernel modules: atlantic
02:00.0 VGA compatible controller: NVIDIA Corporation GA104 [GeForce RTX 3070] (rev a1) (prog-if 00 [VGA controller])
Subsystem: ASUSTeK Computer Inc. GA104 [GeForce RTX 3070]
Flags: bus master, fast devsel, latency 0, IRQ 59, IOMMU group 2
Memory at f5000000 (32-bit, non-prefetchable) [size=16M]
Memory at e0000000 (64-bit, prefetchable) [size=256M]
Memory at f0000000 (64-bit, prefetchable) [size=32M]
I/O ports at e000 [size=128]
Expansion ROM at f6000000 [disabled] [size=512K]
Capabilities: [60] Power Management version 3
Capabilities: [68] MSI: Enable+ Count=1/1 Maskable- 64bit+
Capabilities: [78] Express Legacy Endpoint, MSI 00
Capabilities: [b4] Vendor Specific Information: Len=14 <?>
Capabilities: [100] Virtual Channel
Capabilities: [250] Latency Tolerance Reporting
Capabilities: [258] L1 PM Substates
Capabilities: [128] Power Budgeting <?>
Capabilities: [420] Advanced Error Reporting
Capabilities: [600] Vendor Specific Information: ID=0001 Rev=1 Len=024 <?>
Capabilities: [900] Secondary PCI Express
Capabilities: [bb0] Physical Resizable BAR
Capabilities: [c1c] Physical Layer 16.0 GT/s <?>
Capabilities: [d00] Lane Margining at the Receiver <?>
Capabilities: [e00] Data Link Feature <?>
Kernel modules: nouveau, nvidia_current_drm, nvidia_current
02:00.1 Audio device: NVIDIA Corporation GA104 High Definition Audio Controller (rev a1)
Subsystem: ASUSTeK Computer Inc. GA104 High Definition Audio Controller
Flags: bus master, fast devsel, latency 0, IRQ 18, IOMMU group 2
Memory at f6080000 (32-bit, non-prefetchable) [size=16K]
Capabilities: [68] MSI: Enable- Count=1/1 Maskable- 64bit+
Capabilities: [78] Express Endpoint, MSI 00
Capabilities: [160] Data Link Feature <?>
Kernel modules: snd_hda_intel
Happy to run any commands needed for more info.
The NIC is not showing up under the Isolated device menu, if it did I would have un selected it there.
I am aware this is not the preferred brand NIC.
Cheers for any help,
Mugle
