Hello, I have used the install script. During installation, everything is normal and it terminate successfully. However, when I try to connect to the server using the browser I get “This site can’t be reached” error.
I did some digging and I found out that the plexmediaserver is not running. I have confirmed it’s set to start at boot up and I have tried to start it manually.
Since I am a new user, I cannot attach files… Here a summary of logs entries that I think could be of interest.
Feb 08, 2025 07:48:55.875 [0x806c12000] WARN - Failed to create temp dir "/tmp/pms-22708cdd-aa23-48c2-8c0e-b805ae3b57e2": 13, Permission denied
Feb 08, 2025 07:48:55.876 [0x806c12000] ERROR - Unable to open named mutex 9334581e-7251-4ef7-a8ec-5bfe8e89ff68 with option 1: Permission denied
Feb 08, 2025 07:48:55.937 [0x806c12000] ERROR - SQLITE3:0x10, 6410, statement aborts at 5: [CREATE TABLE "media_parts" ("id" INTEGER PRIMARY KEY AUTOINCREMENT NOT NULL, "media_item_id" integer, "directory_id" integer, "hash" varchar(255), "open_subtitle_hash" varchar(255), "file" varchar(255), "index" integer, "size" integer(8), "duration" integer, "created_at" dt_integer(8), "updated_at" dt_integer(8), "deleted_at" dt_integer(8), "extra_data" varchar(255))] disk I/O error
Seems to be some permission issues… User plex (id:972) have been created. Permission set to Full Control to my media dataset. In the jail shell, I can fully access the mount in /media (as jail user root… dont know how to start shell with plex user…)
What else could I check? thanks!
NOTE: I have changed the script to install FreeBSD 13.3 Release-p8. (was doing same thing with 13.2.
Here is my plex-config file
JAIL_IP="192.168.1.80"
DEFAULT_GW_IP="192.168.1.1"
POOL_PATH="/mnt/mainpool"
PLEX_MEDIA_PATH="/mnt/mainpool/Multimedia"
