SED drives and how to use them properly
Hi there,
Long time FreeNAS and CORE fan, dipping my toe with SCALE right now, and also, I just acquired enterprise SED HDD drives.
I read the documentation on how to setup the SED global password for the SED drives, but I still have a problem understanding the Pool creation process in relation to the SED encryption. If I set my global SED password, is it applied, or is it just a key to read the drives?
From that documentation, here is my understanding:
(Drives are all unlocked already)
-Create a password, save it properly
-Set Global SED password in TureNAS GUI (Advanced-SED Password)
-Use sedhelper setup password to apply it on all SED drives seen by TrueNAS
-Check disk encryption status with sedutil-cli (not sure how precisely)
-Create a pool like usual, without ZFS native encryption.
Am I understanding this correctly?
TIA.
Yes, you are understanding it correctly.
Creating a pool does not do any SED operation other than making sure all disks are unlocked by using the SED password.
