Setting path to .env in home folder instead of with compose - "No such file"
I have a Docker stack running Transmission (through Dockge), which I want to password protect. I know how to pass the Environment variables to the stack using the compose.yaml file, but this leaves the passwords in plain text in a spot where anyone can see them if they have access to the file.
I looked into .env files, and I was able to set up an .env file with the variables I want, and it works if the file is in the same folder as the compose file. However, I’d like to move the .env file to a more secure location, where the local config files for Transmission are, so that everything for this stack is in one place and I can easily recreate / restore it from backup if needed, instead of chasing down files in multiple locations.
I’ve set up a “test” user & stack to figure this out and debug before I set this up in a more stable environment. (This is on TrueNAS 20.10.1, Electric Eel, for the record.)
The path to the (preferred) location for the .env file is:
/mnt/data/home/test/Apps/transmission/transmission.env
When I try to launch the stack, I get the following message:
Failed to load /mnt/data/home/test/Apps/transmission/transmission.env: open /mnt/data/home/test/Apps/transmission/transmission.env: no such file or directory
The directory with the .env file in it also contains the config files for Transmission itself, and the stack and app run if I don’t reference the .env file (or reference it in another location), so I know the directory is accessible by Docker.
I changed the owner on the file in the home folder to root:root to match the one in the Stacks folder, but the error is persisting. I did verify the owner, group, and permissions are identical.
What could I be missing, that it can’t find the .env file in my test home directory, even though it can find the other config files for Transmission?
Compose file for reference:
services:
  transmission:
    image: lscr.io/linuxserver/transmission:latest
    container_name: transmission-test
    env_file:
      - transmission.env
      # - /mnt/data/home/test/Apps/transmission/transmission.env
    environment:
      - PUID=568
      - PGID=568
      - TZ=America/New_York
    volumes:
      - /mnt/data/home/test/Apps/transmission:/config
      - /mnt/data/home/test/Torrents:/downloads
      - /mnt/data/home/test/Torrents/watch:/watch
    ports:
      - 30097:9091
      - 51414:51413
      - 51414:51413/udp
    restart: unless-stopped
networks: {}
As soon as I posed this, I figured it out.
Dockge is the issue. If I run the YAML file from the TrueNAS interface instead of Dockage, it works fine.
User 568 is not going to be able to access the file unless it has at least execute (x) permissions on the directories leading up to it.
Putting a file like this in a home directory is not ideal for that reason.
