Hi i am using TrueNAS-SCALE-22.12.4.2 with the fallowing hardware
Chinese mb with 4x2.5gb intel i226-v nics
intel celeron n5105 cpu
2x 12 tb seagate exos hdd mirror
2x 8 tb wd red pro hdd mirror
32 gb ddr 4 ram
My personel computer has a nic with 2x2.5 gb intel i226v (windows 11 home)
i know i can’t reach 500MBs as my hdds are capped at around 270 MB as they are not striped only mirrored and at seperate pools but when i make transfer at least i would like to see some movements in other interfaces. Both at truenas and my windows only 1 interface seems making transfer
You need - to the very best of my knowledge - two NICs in TrueNAS on different subnets and in different VLANs and two NICs in the client PC in these same two subnets/VLANs.
Thanks for the reply Patrick, i’ve setuped 10.x ips for vlan10 and 20.x ips for vlan 20 from managed switch and even setup a dhcp server for them on both sides only 1 interface willing to show some movements, as shown in the pictures when 1 interface on both sides are making 2gbps transfers other seem to have byte level movements.
well i tried static too and it didnt work. I will check when i get back home. Btw what do you mean by “single default gateway” if you mean truenas, it only lets 1 default gateway anyways, if you mean windows 11 does an ip like 192.168.20.x can use a gateway like 192.168.10.1 which is in different subnet?
Hi Patrick, the settings above worked, apparrently there was a setting in the main switch (there are 2 managed switches, pc and truenas are connected to the small switch and then uplink to a bigger main managed switch) where i need to disable “ingress checking” at the uplink port, if not port will only allow its main vlan.
Thanks for your helps though
