Settings for MacOS Time Machine (how to troubleshoot)
maybe someone can help me to find whats wrong with my setup.
My general samba config is “very old” and not changed the last … I don’t know maybe 10 years.
With Windows works all perfect, but now I habe some Macs and would like to set up Time Machien to create backups on my TrueNAS Box.
All time I try to set up Time Machien I receive on my Mac error like “not all features are supported on this destination”. (Later I can post screenshot - but it’s in German)
My TrueNAS and all Windows and Macs are members Windows 2019 AD Domain (I have Windows Server 2019 Box as domain controller). So all Users and Groups are domain Users/ Groups.
Here is my General Setion from Samba config
# Global parameters
[global]
	ads dns update = No
	allow trusted domains = No
	bind interfaces only = Yes
	client ldap sasl wrapping = seal
	disable spoolss = Yes
	dns proxy = No
	domain master = No
	enable web service discovery = Yes
	kerberos method = secrets and keytab
	kernel change notify = No
	load printers = No
	local master = No
	logging = syslog@0 file
	max log size = 5120
	netbios aliases = mynas001
	preferred master = No
	realm = RJAP.DE
	registry shares = Yes
	restrict anonymous = 2
	security = ADS
	server multi channel support = No
	server role = member server
	server string = My NAS
	socket options = TCP_NODELAY SO_RCVBUF=1048576 SO_SNDBUF=1048576 IPTOS_LOWDELAY IPTOS_THROUGHPUT
	template homedir = /mnt/zpool01/home/%U
	template shell = /bin/sh
	unix extensions = No
	winbind cache time = 7200
	winbind enum groups = Yes
	winbind enum users = Yes
	winbind max domain connections = 20
	winbind nss info = rfc2307
	winbind use default domain = Yes
	workgroup = RJAP
	idmap config rjap: range = 20000-90000000
	idmap config rjap: backend = rid
	fruit:nfs_aces = No
	rpc_server:mdssvc = disabled
	rpc_daemon:mdssd = disabled
	idmap config * : backend = tdb
	aio write behind = yes
	directory name cache size = 0
	dos filemode = Yes
	kernel oplocks = Yes
	veto oplock files = /*.doc/*.DOC/*.docx/*.DOCX/*.docm/*.DOCM/*.dotm/*.DOTM/*.xltm/*.XLTM/*.xltx/*.XLTX/*.xlsx/*.XLSX/*.xlsm/*.XLSM/*.xlsb/*.XLSB/*.xls/*.XLS/*.ppt/*.PPT/*.pst/*.PST/*.mdb/*.MDB/*.ldb/*.LDB/*.vsd/*.VSD/*.mpp/*.MPP/*.qbw/*.QBW/*.qbb/*.QBB/*.qbI/*.qbl/*.dxf/*.DXF/*.dwg/*.DWG/*.cdr/*.CDR/*.bak/*.BAK/*.ord/*.xlo/*.igs/*.ipt/*.ipj/*.slp/*.stp/*.opt/*.xli/*.stl/*.cur/*.sjb/*.log/*.LOG/*.sbs/*.iam/*.idv/*.pcbdoc/*.PcbDoc/*.PCBDOC/*.dbf/*.DBF/*.cdx/*.CDX/*.mrimg/*.MRIMG/*.tmp/*.TMP/*.imd5/*.IMD5/*.db/*.DB
And here part of the new share definition I have created yesterday.
(First I have created a new dataset for SMB, and than this new share)
[mymini001 Time Machine]
	ea support = No
	kernel oplocks = No
	kernel share modes = No
	mangled names = no
	path = /mnt/zpool02/backup/mymini001 Time Machine
	posix locking = No
	read only = No
	smbd max xattr size = 2097152
	vfs objects = fruit streams_xattr
	fruit:locking = none
	fruit:time machine = yes
	fruit:resource = stream
	fruit:metadata = stream
	fruit:encoding = native
	nfs4:chown = true
	ixnas:dosattrib_xattr = false
Ideas whats wron or better how to resolve it?`
