Should I switch to rsync?
Correct
That’s actually a good “exception to the rule” that I can include. I just don’t have the time at the moment, and this mermaid plugin can act really weird sometimes.
How did you “quote” my post? Did you highlight the chart and then click quote? It just dumped a bunch of text instead of quoting the actual chart itself.
EDIT: I went ahead and made the quick fix.
Yes. Yes it did.
I wondered if it would work. It didn’t.
(Now that you’ve seen the result I’ve snipped it. )
BTW, for the record, this does not work
Turns out it works on the enclosing datasets but not actually the replicated datasets, which as @winnielinnie stated will rebase the snapshots from the previous replicated tip
Luckily I read this last comment here as I really thought I am too stupid to get it working as described :wink:
