No, it does not because passphrases do not allow unattended boots. I want / need to be able to start / reboot my server without sitting next to it.
Good to know. Thanks. That makes the nextcloud and jellyfin use case obsolete for me.
Got it! Thanks ! I very much appreciate for your time and patience.
I second that. Please consider setting up your own VPN like Wiregard and/or Tailscale (which relies on Wireguard). Setting-up Tailscale is extremely easy and scales very well. Pure wireguard is interesting also. I use both.
Sitting next to? You just login to the UI and unlock the dataset with your passphrase.
Ok. But still, this is not an unattended reboot. For example, after a power failure it will not recover without admin interaction.
True but you can’t have it all. You either want your data protected when/if it’s powered down or you don’t.
TrueNAS Enterprise does have an option like the one you mentioned but that’s only available on Enterprise systems.
Why do you say that? I have my data protected at rest AND the keys are in a remote location, downloaded during boot.
Perfect. My point is for a free storage appliance using ZFS encryption keys or passphrase is going to cover 99% of use cases. I can see how your config goes that one step further but for most users it’s just not necessary.
Exposing an application like Nextcloud running in a container to the Internet is not exposing your TrueNAS. Many users do this and if you keep your Nextcloud updated, use a reverse proxy with TLS and strong passwords and/or 2FA is considered safe.
The warning not to expose your TrueNAS means the web UI and SMB and friends. Yes, people have been doing this.
Thanks for this clarification. That is pretty much how I currently do it with my debian server. I use nginx-proxy-manager to pass the traffic on port 80 and 443 to the respective docker container. And before the reverse proxy I have geoblocking and fail2ban with iptables.
Nevertheless, I believe a that at least he geoblocking and fail2ban part is not easily implemented with truenas. Not to mention the key management.
I do not want to create negative vibrations here. I very much like truenas as a home appliance. I like it more than openmediavault or unraid which I have tested too. I even purchased a license for unraid. And I tested this really heavily. But truenas is my winner in this trio.
You can run custom docker compose. This topic can be helpful – Electric Eel - How I am using Dockerfile, .env files, compose files.
That is a good point. May be I just copy my existing nextcloud config (portainer stack) to truenas, tweak it a bit for folder names etc. and see if that works. I will do that!
Downloaded automatically during boot, which automatically unlocks your datasets?
I guess this has the advantage of deleting the keys on the remote server if your NAS is stolen.
Exactly. I simply take the keys offline.
Just to add my 2 cents here: in fact, I prefer neither. The GUI is fine to explore, experiment and learn. Specifically for TrueNAS it also serves as an indicator of what the user is supposed to do; if it is not featured prominently in the GUI, there be dragons ![]()
In production I however prefer infrastructure as a code and I am managing (nearly) all of my homelab in Ansible. While the API is great and I have managed to script things I need, I would love to see an official TrueNAS collection. The https://github.com/arensb/ansible-truenas seems to be an independent effort that is incomplete and will necessarily lag beyond the development.
Here the Debian (or any setup that is not a locked-down appliance) install clearly wins.
Just a quick note that I plan to use a network management software to monitor the health of my various devices including my ZFS NAS (let’s call it this way), but I don’t know yet what to use.
I am quite satisfied with Observium.
Although not a direct option, could this not be scripted to run at startup using their API? I came across the following which could be of use: How to Unlock Encrypted Volume via API? - #4 by coolaj86
Good idea about storing the keys remotely so that you can disable access if the hardware is stolen. I store them off device as well but would like an option to decrypt the volumes automatically on boot (without storing on the same device) so may look into this.
Here is how I do it. This works for my main PCs with Endeavouros and debian as well as with my unraid test server. It works with LUKS and with native zfs encryption.
I have a private repo on github. This repo is not visible to other users. I have my keyfiles for zfs uploaded to that repo.
During boot, before importing zfs, I download the keyfile with:
curl -L -H “Accept:application/vnd.github.raw” \
-H “Authorization: Bearer $TOKEN” \
-H “X-GitHub-Api-Version: 2022-11-28” \
https://api.github.com/repos/<username>/<reponame>/contents/$keyfile \
-o $tmpfile &>/dev/null
The $TOKEN is the security token from github. $keyfile is the filename in the repo. $tmpfile is where the keyfile is being stored. This is in /tmp within an extra directory with restricted access rights so that the keyfile does not survive a reboot
That is reasonably save for me. A burglar steeling my hardware must have retrieved the keyfile before I get aware of the missing hardware. Otherwise I have enough time to take the keys offline or invalidate the $TOKEN.
And the github username that I use for this activity is unknown and can not be associated with my person. And the reponame is unkown and it is invisible anyways. That makes it very hard for a burglar to retrieve the keyfile upfront before they steel the PC. And why would they do this anyways?
Long story short, for a regular theft this is save enough.
For my 3rd box I went truenas bare metal. The hpe microserver did not have nvme so I bought a usb to sata ssd adapter and an m.2 sata ssd. Not mirrored but I keep config and setup on other nas devices.
Added sata.drive for vm storage.
Building similar system for a friend that does have nmve but not mirrored.
Ive not lost data in over a 2 decades. Have lost boot drive a couple of times but was always separate from data drives and not a big deal to recover from.
I would make sure whatever boot system you use, it can fully boot all by itself without user interaction.
Can you please elaborate?
